Baxter61
360, all new, just needs to be cleaned and assembled, will assemble for you if needed.
Block .030 over, Speed Pro h405cp Pistons, about 8.5:1 compression, Rods resized with ARP bolts, new balancer, b&m flexplate so you can use this setup with a neutral balance converter
Comp xe268h cam and lifters, new double roller timing chain. 596 heads rebuilt. Performer intake. Have either truck or car pan, new oil pump and pickup. Comes with front timing cover and water pump, basically add your carb (have carbs if you need on), distributor and accessories and go.
$1600 plus shipping from Gladstone, OR 97027. Can ship fastenal store to store for about $250. Message me here
