360 Flex Plate
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
I need the special flex plate to use a neutral balance torque converter in my 727 360. Any body have one? Or can tell me the B & M part number I need?
if your engine is internally ballanced, you might be able to use a 318 one. But don't quote me on that. I was able to use a 318 flywheel on my internally ballance 440.
Ask around, it might work for you.
Phil
360's are externally balanced, what did you do to the engine?
If it is a Magnum 360 the part number would be 10242, but if it is an LA 360 it is the 10236 that grimreaper said.
As a side note on this... when putting it on the engine, the side with the SFI sticker faces out, right?
