1. doopdoop67
    doopdoop67 Well-Known Member
    225
    61
    Sep 8, 2015
    pacifica california
    Local Time:
    1:44 PM
    Hey guys quick question, I got a 360 mopar and I don’t have a flex plate for it. Where can I get one. Here a picture
  2. JBurch
    JBurch Well-Known Member
    1,819
    949
    Oct 17, 2009
    Owego, NY
    Local Time:
    4:44 PM
    • Like Like x 1
    • doopdoop67
      225
      61
      Sep 8, 2015
      pacifica california
      Local Time:
      1:44 PM
      Would the one from my 318 work?
    • 70aarcuda
      70aarcuda Master Hoader of SBM FABO Gold Member
      15,460
      3958
      Jan 16, 2005
      las vegas
      Local Time:
      1:44 PM
      just remember the 360 is externally balanced....either you need a weighted flexplate OR a weighted converter ....one or the other....
      so yes the 318 flexplate will work if you use a weighted converter....and make sure the flexplate and converter have the same diameter ...aka bolt circle....
      • Agree Agree x 2
      • Like Like x 1
      • doopdoop67
        225
        61
        Sep 8, 2015
        pacifica california
        Local Time:
        1:44 PM
        Perfect thank you. I want an after market converter with the “mini stall” any recommendations?
      • 12many
        12many Well-Known Member
        1,170
        1438
        Dec 14, 2016
        SC
        Local Time:
        3:44 PM
        We just installed a B&M 10239 ( externally balanced 360 with 904) on my sons 78 Magnum. I forget the part# for the same engine with the 727. Its heavy duty, overkill for the street, but not much out there if you want to run an unweighted converter. We found one on eBay, never used for about $85.
      • gregpurcell
        gregpurcell Greg Purcell
        2,072
        180
        Aug 21, 2008
        Near Savannah, GA
        Local Time:
        3:44 PM
        I have used stock flexplates for $5 plus the ride if you are using the factory weighted converter. If you want an aftermarket converter run the B&M scalloped 360 balanced flexplate.
        B&M Flexplates 10236
        • Agree Agree x 1
        • doopdoop67
          225
          61
          Sep 8, 2015
          pacifica california
          Local Time:
          1:44 PM
          What converter do you run?
        • gregpurcell
          2,072
          180
          Aug 21, 2008
          Near Savannah, GA
          Local Time:
          3:44 PM
          I'm not running anything right now because I don't have a car. If you use a factory torque converter use a factory flexplate
        • forphorty
          forphorty Well-Known Member
          672
          253
          Jan 19, 2006
          Local Time:
          3:44 PM
          There are two sizes of converters from the factory. 10.75 and 11.75. different bolt circles.
        • gregpurcell
          2,072
          180
          Aug 21, 2008
          Near Savannah, GA
          Local Time:
          3:44 PM
          The six cylinder used a different flexplate and the Hemi had an 8 bolt plate.
          Some of the 67 and down flexplates had a smaller pilot (center hole).
          Other than that from 68 into the 80s all mopar v8s used one of two factory flexplates. ALL 6 BOLT CRANKS HAD THE SAME BOLT CIRCLE! If you keep the two (10 inch and 11 inch measured diagonally across the converter bolt holes) in the shop you will always have the correct one for a 904 or 727 transmission. Also note that in some cases a 904 and a 727 use the same flexplate. You either had a 10 inch converter (smallplate) or an 11 inch converter (large plate)
          • Like Like x 1
