Uncle Bob
Shiny paint causes stress.
Yeah the truth on the pushrod length will be known when I drop them in and try adjusting the rockers. I'm still disgusted but might be over it enough to work on it tomorrow.I would think you would need to factor in the cup depth. I would measure with the push rod in it.
I backed the adjustment on the #1E (problem) lifter off 3/4 turn. Should be at 0 preload. Then I primed it and checked the lifter about 10 minutes later It was already bleeding off so I'm unconvinced the preload has anything to do with it.
