Rapid Robert
small port mag heads/weiand large port "x-cellerator" alum intake. On mockup I'm gonna need at least 3/16 and possibly 1/4" thick side gaskets to raise the intake to where the larger intake ports are reasonably centered above/below the smaller head ports plus & more importantly getting the bolt holes to line up & that is with significant elongating (higher) the intake bolt holes. does anyone custome make intake gaskets for this and I cant even find sheets of gasket material that thick. What am I missing here.. thank you for your time. RR
