360 Magnum 6 pk mock up
General Discussion
  1. Brooks James
    Brooks James Dustoff
    1,313
    654
    Dec 12, 2020
    Fruitland Park Fl
    Local Time:
    2:03 PM
    Carbs need to be rebuilt factory coating or polished, choke flaps removed, air cleaner stud mount ground out
    Base of adapter milled at an angle to make it level and reduce height
    Install linkage
    Air cleaners wont work im not going to cut the hood
    Super coil mounted to firewall
    45 or 90 degrees thermostat housing
    Cost
    Adapter 150
    Carbs and kits 300
    Linkage 100
    Misc 50
  2. Cope
    Cope Fusing with fire
    5,158
    6742
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:03 PM
    Would look more at home in a early ford
    Maybe its the hats but it looks "off" to me?
    Got a pic with the hats off?
    Progressive or all in?
    That is certainly hot rodding tho.
    Well done sir.
  3. Brooks James
    1,313
    654
    Dec 12, 2020
    Fruitland Park Fl
    Local Time:
    2:03 PM
    Everything Is just sitting there
    Not bolted down slightly skewed
    I wanted to see If everything fit
    The adapter Is from Vintsge Speed
  4. Cope
    5,158
    6742
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:03 PM
    Progressive linkage or all in.
    My 360 breathes through all 8 barrels all the time and it rips. 6 should be fine if your comp ratio is decent.
    Id be a little concerned at fuel/air mixing due to the low plentum volume of the adapter. So maybe tip in the center to get air moving then dump in the last 4 after?
    Do you have a wide band in the car? Im not a fan of tuning multi carb set ups the old fashioned way.
  5. Brooks James
    1,313
    654
    Dec 12, 2020
    Fruitland Park Fl
    Local Time:
    2:03 PM
    A 150 hp nitrous plate is going under the adapter
  6. diymirage
    diymirage HP@idle > hondaHP@redline
    25,252
    22739
    Oct 12, 2012
    michigan
    Local Time:
    2:03 PM
    Yes!
    Change out the center cap aircleaners for a six pack one and it would look spot on
    (And probably fit better under the hood too)
  7. Brooks James
    1,313
    654
    Dec 12, 2020
    Fruitland Park Fl
    Local Time:
    2:03 PM
    Progressive
    Getting afr for both banka
    Yes im hoping the mid carb Will start the flow
    I suspect a Good 4 barrel and intake will out do it but im going to be at 500 hp
    And am not concerned about leaving some hp on the table
    • Like Like x 1
    • Brooks James
      1,313
      654
      Dec 12, 2020
      Fruitland Park Fl
      Local Time:
      2:03 PM
      I thought about that i have a buddy that has a sheet metal shop and we are wirking on a prototype i like the brushed stainless look. And brass
    • mopowers
      mopowers Well-Known Member
      5,833
      2940
      Feb 15, 2006
      West Sacramento, CA
      Local Time:
      11:03 AM
      Well, you definitely don't see that everyday. Hope it works out for you.
      What's the rest of the engine combo?
    • Brooks James
      1,313
      654
      Dec 12, 2020
      Fruitland Park Fl
      Local Time:
      2:03 PM
