360 magnum cam choice
Small Block Mopar Engine
  1. 7dart0
    7dart0 Well-Known Member
    434
    45
    Apr 20, 2012
    peabody,ma
    Local Time:
    5:22 AM
    my engine is a 2001 360 magnum block stock bottom end, hughes EQ heads with 2.02 intake valves,TTI step headers, edelbrock performer rpm air gap intake, 750 proform mech. secondary. cam is crate 360 cam supposedly I think its smaller. stops pulling around 5800.
    A904 with 2800 stall with forward manual valvebody, 8.75 w/4:10 suregrip
    I've gone 12.40 @ 110 in the 1/4 mile with this setup
    lookin at Oregon cam #1357 grind
    230/236@.050
    112 lobe separation
    .515/.515 w/1.6rockers
    this custom one from a member
    bullet cam
    237/245@.050
    108 lobe separation
    .550/.550 w/1.6 rockers
  2. gregsdart
    gregsdart Well-Known Member
    585
    147
    Jun 20, 2004
    mn
    Local Time:
    10:22 AM
    I would go with the custom bullet cam. It has a lot more duration, and particularly more overlap duration. You may need more stall to be happy. Do the valvetrain right, and the motor will pull to over 6,000 easily, and with the proper valvetrain parts will pull to 6500 and should make max power about 6,000. I have a very similar cam, at least duration wise, with 235/249/107 duration and lsa. It made peak hp at 5700. My motor is a 408, but you can look up the magnum build in HotRod magazine for an idea of the power curve for your size motor. Depending on your compression, the hp could be lower than the HR build.
  3. 7dart0
    434
    45
    Apr 20, 2012
    peabody,ma
    Local Time:
    5:22 AM
    thanks. I used a .028 felpro head gasket. heads are 62cc chambers.
  4. j par
    j par Well-hung Member
    13,506
    6207
    Jul 2, 2014
    Portland Oregon
    Local Time:
    2:22 AM
    Both times I've had my cam ground I've had done at Oregon cam grinding after I talk with Ken. Have you talked to Ken at Oregon cam grinding he's very easy to talk to? Or did you just look up the cam profile? when I wanted a cam like the one you talking about with long durations and high lift he gave it to me and it maxed out the motor and ran great. 11-4 at a hundred and nineteen with my Stroker. Which if I could 60 foot the car it should have done high tents easily. This last summer I called him and said I want to be able to cruise to the cruise- ins with my wife and I want the car to idle a bit and I wanted to have that are characteristics but still not lose all its power. And like magic the cam recommend by Ken is making my car perform exactly the way I want it as a matter of fact I hope it stops raining today so I can go for a drive. nice guy too bad you live so far away you could walk up and talk to him and look over that list of different cams with him. really nice personable guy who has probably drag raced with most of the cam profiles he provides. My -2
  5. Wyrmrider
    Wyrmrider Well-Known Member
    1,330
    509
    Sep 5, 2016
    los angeles
    Local Time:
    2:22 AM
    does not your block have the provisions for HR
    are you looking for solid or Hyd?
    Bullet has MOPAR masters every 2 degrees and are easy to talk with
    I do not know Ken and how he obtains/ makes his masters
    are they universal or Mopar specials
    He does have a good reputation
    that's a big difference in timing between those two cams with the big difference in lca
    do you drive this on the street?
    • Like Like x 1
    • j par
      13,506
      6207
      Jul 2, 2014
      Portland Oregon
      Local Time:
      2:22 AM
      Honestly I don't know where it gets his master's. All I can say is I've had good results. But in my personal opinion I only see both of them regrinding any spec they wanted to in the world. Out of any cam. I can't imagine calling Ken with any spec I wanted and him not just saying, okay. Maybe Bullet has an owner you can talk to or maybe that's a big company with people answering the phones? I know with Ken you will personally talk to Ken who grinds these cams and races the cams and probably have driven in cars with most of his grinds. I mean I have no objections to driving up there with my car right now and letting him feel difference between the old cam and the new cam. But after all these years I'm sure he knows exactly what it's going to do. More of my-2
    • Abodybomber
      Abodybomber Breaking street machines , since 1983.....:) Legendary Member
      31,731
      10454
      May 21, 2011
      Arroyo grande ca
      Local Time:
      2:22 AM
      Actually, like the Oregon grind ,with 1.5 rockers ...Valve train stability, is more important than that extra .010 "extra lift " ,by a long shot.
      • Agree Agree x 1
      • 7dart0
        434
        45
        Apr 20, 2012
        peabody,ma
        Local Time:
        5:22 AM
        I do run this car in the street on nice days. Its a hydraulic roller cam motor with the factory 1.6 rocker ratio.
        I have not spoken with anyone at the cam companies.
      • 360duster
        360duster Well-Known Member
        1,077
        182
        Nov 23, 2008
        Bavaria / Germany
        Local Time:
        11:22 AM
        how big of a cam can the stock pistons handle without ptv clearance trouble? I know that the 5.9 Mag has got some little dish in the piston, but no real valve reliefs.
        Michael
      • Abodybomber
        31,731
        10454
        May 21, 2011
        Arroyo grande ca
        Local Time:
        2:22 AM
        Piston are usually ".050 -060 " ,in the hole. Valve train is limited to ".510 - .520 depending on valve train decision. To be honest, I don't see a need beyond "480-490 lift " unless the heads flow more than 260 ...270 ,on the intake side....
      • Bobzilla
        Bobzilla Well-Known Member
        501
        321
        Aug 10, 2017
        Livonia, Michigan
        Local Time:
        5:22 AM
        Retainer to guide clearance is the issue on Magnum engines with factory heads. EQ heads are designed as replacements so I suspect that will be the case with EQs as well, although I have not measured them yet.
        If the guides on 7dart0's EQ heads were not cut down for more lift potential before the engine was built, that needs to be measured before selecting a cam.
        • Agree Agree x 1
        • Bobzilla
          501
          321
          Aug 10, 2017
          Livonia, Michigan
          Local Time:
          5:22 AM
        • gregsdart
          585
          147
          Jun 20, 2004
          mn
          Local Time:
          10:22 AM
          7dart0 the cam i suggested, will make Excelent power, but will have valve to piston problems and possibly valve guide clearace problems as well. I must have had brain freeze and plain overlooked the part about the stock bottom end.
        • dusted
          dusted FABO Gold Member FABO Gold Member
          329
          274
          Sep 24, 2006
          Creedmoor, NC
          Local Time:
          5:22 AM
          I had the similar combo but less gear, ran slower ET but same MPH and pulled to 6100. I had a Hughes cam and valvesprings.
        • 7dart0
          434
          45
          Apr 20, 2012
          peabody,ma
          Local Time:
          5:22 AM
          Thanks for the info. Dusted that seems like a good cam. I gather if I keep it under 550 lift I should be ok. I'm just trying to absorb as much info as I can so I dont have do it twice. Lol
        • Wyrmrider
          1,330
          509
          Sep 5, 2016
          los angeles
          Local Time:
          2:22 AM
          Duration
          Advertised
          .050 tappet lift
          gotta luv Hughes
          • Like Like x 1
          • Project73
            Project73 Project 73
            29
            1
            Apr 20, 2009
            North Carolina
            Local Time:
            5:22 AM
          • Wyrmrider
            1,330
            509
            Sep 5, 2016
            los angeles
            Local Time:
            2:22 AM
            I obviously missed the MAGNUM in the thread title
            we are talking HR here - right
            Mike Jones has the best roller profiles- inverse radius for more early lift and proven in the Indy motors
          • Austin Boone
            Austin Boone Member
            6
            0
            Aug 28, 2017
            tennessee
            Local Time:
            4:22 AM
            i have a .566 lift cam from hughes in my magnum 360 with a stock bottom end and heads as well as stock valvetrain except springs obviously got them from hughes as well.
          • AJ/FormS
            AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
            15,853
            4779
            Jan 19, 2014
            South-Central Manitoba,Canada, 900ftelevation
            Local Time:
            4:22 AM
            Yeah and it ain't in the archives either. It's like they don't really want to sell cams.
          • AJ/FormS
            15,853
            4779
            Jan 19, 2014
            Local Time:
            4:22 AM
            Between these two, I'd go bullet if I still had pressure enough left for to have fun as a streeter. But the thing is with a roller, that 237@.050 might translate to 290/300/108/79overlap. and in at 104 say would get you an Ica of 69* maybe. And that in a 9.5 Magnum equates to just 146psi, so not real snappy at typical street rpms. Thank goodness for the 4.10s and 2800TC.
            But guess what, the Oregon 230* could have the exact same 69* Ica so makes the same pressure, but with a loss of 16* of overlap, will definitely make less power at the track. 283/291/112/63overlap
            But if you got the Oregon 230 ground on a 108, you would be able to reset the Ica to 66* and might get 151psi, with some overlap back; 283/291/108/71overlap.and a lil more street friendly, at the expense of ultimate power, as compared to the Bullet 237.
            _________________________________
            In my street 367,I ran the Mopar 292/292/108/76overlap for one summer at 11.3Scr/about 185psi. With just a 9.44 starter gear and a manual trans, I was only too glad to get rid if it. I would entertain using it now tho with my more 292-friendly gears.
            I modeled with clearance ramps of 53 and 55 degrees, guesses to be sure.
            and elevation at Sea-level.
          • forphorty
            forphorty Well-Known Member
            586
            180
            Jan 19, 2006
            Local Time:
            4:22 AM
            It sounds like the engine runs pretty good for the known parts you have. If'n it were me, I would leave the engine alone for now. At 110 mph you should be running about 3 tenths faster than you are. Do you have slicks on this? 2800 stall ain't much. I would throw more converter at it. Converter change and a little fine tuning this and that could potentially put you in the 11.90 range. Cam change alone is not likely to get you there, especially since you are not sure what cam is in it now. A cam swap might get you zilch.
          • MOPAROFFICIAL
            MOPAROFFICIAL Well-Known Member
            3,339
            2325
            Jun 1, 2016
            breakwater
            Local Time:
            2:22 AM
            "Generally speaking" I like to shoot for .030-.050 more lift over peak flow "or once the gain is less than 8cfm" for maximum type efforts.
            • Like Like x 1
            • Abodybomber
              31,731
              10454
              May 21, 2011
              Arroyo grande ca
              Local Time:
              2:22 AM
              Makes sense ,to keep the charge pulling, got it...
            • 7dart0
              434
              45
              Apr 20, 2012
              peabody,ma
              Local Time:
              5:22 AM
              Yes I run a 26x8.5 slick.
