360 Magnum engine
Mopar Racers Forum
  1. Ceedawg
    Ceedawg Well-Known Member
    478
    305
    Aug 2, 2016
    Va
    Local Time:
    10:20 PM
    About finished with my 70 Duster E/stock. 340 is not ready yet so I'm using my 360 that I built as a 360-380 and wondering what the rpm limit is. I used the factory port templates and has the 1.7 roller rockers kit. M1 intake/race Q-jet. Basically to know what gear in the Dana. Thanks
    Mike
  2. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
    31,061
    10264
    May 21, 2011
    Arroyo grande ca
    Local Time:
    7:20 PM
    Converter stall ,transmission and rear tire height...?
  3. Ceedawg
    478
    305
    Aug 2, 2016
    Va
    Local Time:
    10:20 PM
    92.5" roll out 9x30 904 Dynamic 8" 4800?
  4. Ceedawg
    478
    305
    Aug 2, 2016
    Va
    Local Time:
    10:20 PM
    Really, nobody on here knows what the rpm level of a 360 is? I've never ran a small block before so I don't know when these Magnum heads start laying over.
  5. Jadaharabi
    Jadaharabi FABO Gold Member FABO Gold Member
    8,946
    10221
    Jan 8, 2016
    Peoria, Illinois
    Local Time:
    9:20 PM
    I have 4.88s with 29.5 inch tires, in my 73/74 Duster stocker that's not all together at the moment. The 360 is 75% together and the 340 is totally apart and needs assembled.
    What Dana do you have under yours?
  6. dadodgekid
    dadodgekid When in doubt... floor it
    673
    224
    Nov 25, 2013
    Palm City , FL
    Local Time:
    10:20 PM
    it will be all over at 6200 -6400 if it still has the 380HP crate motor cam. (.508 roller i believe)
    • Like Like x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      77,248
      54339
      Jun 7, 2010
      Georgia
      Local Time:
      10:20 PM
      If it has a decent HP lifter in it, it might pull to 6500.
      • Agree Agree x 1
      • Walker434
        Walker434 Well-Known Member
        965
        711
        Aug 29, 2012
        Nashville, TN
        Local Time:
        9:20 PM
        Mine starts laying over at 6,000. I've turned up to 6,300 and always slowed down past 6,000.
        • Thanks! Thanks! x 1
        • Ceedawg
          478
          305
          Aug 2, 2016
          Va
          Local Time:
          10:20 PM
          Dana 60, I have 4.88 5.13 5.38 5.57 don't know whitch one to use yet. Might look for 4.56 at Carlisle. I'm leaning to the 4.88 with the 360.
        • furrystump
          furrystump Well-Known Member
          1,387
          905
          Nov 13, 2004
          Local Time:
          3:20 AM
          All done 6000-6300 is my guess.
        • Jadaharabi
          8,946
          10221
          Jan 8, 2016
          Peoria, Illinois
          Local Time:
          9:20 PM
          Was wondering if you had a car dana or a converted truck one.
          Ask physixx what he uses in his stocker.
          His avatar sez it all
        • Ceedawg
          478
          305
          Aug 2, 2016
          Va
          Local Time:
          10:20 PM
          Yes that one, 6000 will give a good idea on gear. I'll use the 5.13 for the 340. Thanks to all for the input
          Mike
        • dadodgekid
          673
          224
          Nov 25, 2013
          Palm City , FL
          Local Time:
          10:20 PM
          4.88 should be about right with the 30" tire with the 4800ish stall and the 360.
        • 273
          273 Well-Known Member
          3,744
          1498
          May 14, 2012
          Ontario
          Local Time:
          10:20 PM
          Heres a dyno of the 380 hp create engine if that helps.
          • Ceedawg
            478
            305
            Aug 2, 2016
            Va
            Local Time:
            10:20 PM
            5800 is tops then for the out of box engine, wonder is it cam or head airflow holding it back?
            I did the bowl work with the 1.7 rockers, maybe more? May do a little more since I now have the guide and seat machine, flow bench is in the works, need to get that finished.
            Thanks for info
            • Like Like x 1
            • Ceedawg
              478
              305
              Aug 2, 2016
              Va
              Local Time:
              10:20 PM
              Is there really a difference?
            • 273
              3,744
              1498
              May 14, 2012
              Ontario
              Local Time:
              10:20 PM
              Well heres a dyno of a 300 hp create vs a top end change to a comp roller 275 airgap and eddy heads. Your mods might be closer to that one.
            • Ceedawg
              478
              305
              Aug 2, 2016
              Va
              Local Time:
              10:20 PM
              According to the Wallace thingy, I might need the 4.56 gear
            • Jadaharabi
              8,946
              10221
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              9:20 PM
              Unless they changed the rules for rear ends in stock Eliminator. You are not allowed to use a truck rear end.
              The way to tell the difference between the truck and the car rear end is the truck rear end does not have the mount for a pinion snubber.
              Don't quote me on that but that was my understanding of the rules.
            • Ceedawg
              478
              305
              Aug 2, 2016
              Va
              Local Time:
              10:20 PM
              I think when they say no truck rears they mean no floating hubs (8 lug wheels), might be wrong. Especially since there was no production Dana for an a-body.
            • 70aarcuda
              70aarcuda Master Hoader of SBM FABO Gold Member
              16,480
              5198
              Jan 16, 2005
              las vegas
              Local Time:
              7:20 PM
              Sorry had to quote you...Stockers around here are all using Dana 60s.....which can be ordered with or without provisions for pinion snubber...and I would say,,,,99,999% of the stockers use Cal Tracs which probably means they do not use pionion snubber...
              • Thanks! Thanks! x 2
              • Ceedawg
                478
                305
                Aug 2, 2016
                Va
                Local Time:
                10:20 PM
                What rpm are you turning in those 3 cars? Are they cast cranks?
              • ddartdude
                ddartdude Well-Known Member
                646
                270
                Jan 1, 2007
                Port St. Lucie, Florida
                Local Time:
                9:20 PM
                If it's a true Magnum engine, I hope you used the correct type of weighted torque converter.
              • Jadaharabi
                8,946
                10221
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                9:20 PM
                I thought the rules said that you had to use a factory manufactured rear end from the factory that was made for a car.
                Which to me would mean a Dana that was manufactured for a b-body or an e body or station wagon that had been narrow to fit the a body. Or the a body Dana that direct connection made.
                But if what you say is true I already have a 52 and 5/8 Dana that I could shove under mine. I would rather have the Dana than the eight three quarter even though I'm running a 904 with 8 inch converter with the low gear set in the 904.
                I have slide-a-links.
              • 70aarcuda
                16,480
                5198
                Jan 16, 2005
                las vegas
                Local Time:
                7:20 PM
                the stock stroke 360 are cast cranks...at sea level 7200 thru the traps....in Vegas 6800 ish...
                not using heavy pistons or heavy stock rods....
