360 magnum flexplate?
Discussion in 'Magnum Engine Swaps' started by wes beem, May 6, 2018.
  1. wes beem
    wes beem Well-Known Member
    373
    62
    Apr 16, 2017
    ohio
    Local Time:
    1:53 AM
    Im swapping a 318 magnum out for a 1998, 360 magnum in my 70 dart 727 transmission. I keep seeing that i need a weighted flex plate because the 360 is externally balanced but i can not find a single flexplate anywhere online thats for the newer magnum motors. all i can find is the LA360 ones. Can someone whose done this before please link me to the exact part i need to buy?
  2. MoparLeo
    MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
    367
    187
    Feb 10, 2016
    Moreno Valley, Cal. So. Cal.
    Local Time:
    10:53 PM
    OK. You are taking the 5.2/318 Magnum engine from a 98 Dodge something and want to swap it into a 70 dart with the 727 or the L.A./magnum block. Do it have fuel injection ?
  3. 67Dart273
    67Dart273 Well-Known Member
    38,310
    5898
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    10:53 PM
    Do you have the flexplate out of the original vehicle the Magnum was in? Just use that. If you are using an LA converter my understanding is that you can "oblong" the odd mounting hole. Make sure your converter is "neutral" balance
  4. 67Dart273
    38,310
    5898
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    10:53 PM
    He said 360, so 5.9
  5. etngeorge
    etngeorge Well-Known Member
    54
    8
    Jul 24, 2013
    Dandridge,Tn
    Local Time:
    1:53 AM
    B&M did make these flexplates but I think they discontinued them. Check with cope racing transmissions, that's where I found one.
  6. wes beem
    373
    62
    Apr 16, 2017
    ohio
    Local Time:
    1:53 AM
    i have a 70 dart that has a 98 318 in it, i wanna swap said 318 for a 98 360.\
  7. wes beem
    373
    62
    Apr 16, 2017
    ohio
    Local Time:
    1:53 AM
    the only ones they offer are 71-92 :/ same with the B&M
  8. etngeorge
    54
    8
    Jul 24, 2013
    Dandridge,Tn
    Local Time:
    1:53 AM
    Current catalogs don't list the B&M for magnum 5.9 but they were made. Have to find one used or someone who still has one in stock. If I can find the paperwork, I'll supply the part number. Maybe someone else can chime in that knows that part number.
  9. replicaracer43
    replicaracer43 Old school member
    3,731
    2151
    Oct 10, 2008
    View My Photos
    Local Time:
    12:53 AM
    The factory truck 5.9 magnum flexplate is what you need, may need to elongate one hole, easy as pie.
    • Agree Agree x 4
    • etngeorge
      54
      8
      Jul 24, 2013
      Dandridge,Tn
      Local Time:
      1:53 AM
      Looked thru some old threads and B&M number was 10242. Don't know why it was discontinued.
    • 1994redram
      1994redram FABO Gold Member FABO Gold Member
      964
      456
      May 9, 2012
      Oklahoma
      Local Time:
      12:53 AM
      Just get a stock 5.9 flexplate. One hole will need to be opened up about 1/8 or so, not much. Use a neutral balance converter which you should already have. I have a 1994 5.9 and it had a 318 flexplate but a weight on the converter. Several at the juslnkyard were the same way. So, I think you need a 1996 and newer flexplate. I bought mine brand new at oreillys. Advance auto had them much cheaper but oreillys price matched.
      • Agree Agree x 1
      • 1994redram
        964
        456
        May 9, 2012
        Oklahoma
        Local Time:
        12:53 AM
      • wes beem
        373
        62
        Apr 16, 2017
        ohio
        Local Time:
        1:53 AM
        thanks much guys,. i actually have the stock factory truck one that came with it i just did not know it was compatible with the 727 tranny. I freakin love this site.
      • JDMopar
        JDMopar Well-Known Member
        1,685
        553
        Jan 19, 2012
        Candler, NC/Myrtle Beach, SC
        Local Time:
        1:53 AM
        Look at the money you just saved....lol. Like a few others have said, just test bolt it to your converter so you can see where to rat the one hole out. Mark it like you would have with an original 727 flex plate if you like, but it should fit the same no matter how you try to bolt it.....unlike an original that only fits one way.
      • MoparLeo
        367
        187
        Feb 10, 2016
        Local Time:
        10:53 PM
      • replicaracer43
        3,731
        2151
        Oct 10, 2008
        View My Photos
        Local Time:
        12:53 AM
      • 67Dart273
        38,310
        5898
        Oct 14, 2010
        Idaho
        View My Photos
        Local Time:
        10:53 PM
        Can you show where that is "for sure?" The years mentioned seem to indicate magnum......I'm not at ALL sure YET whether that one is LA or magnum
        Application I've found for the one in question says
        APPLICATION: Chrysler Small Block 360 with TF727, 1993-99
      • replicaracer43
        3,731
        2151
        Oct 10, 2008
        View My Photos
        Local Time:
        12:53 AM
        Actually no, nothing I saw stated it was for those years, but if so, then yes, it would work. I know the magnum has a different offset weight amount than LA, I was thinking that was the "LA" version... but i think the OP did say he had the factory flexplate, so he's good to go.
      • 67Dart273
        38,310
        5898
        Oct 14, 2010
        Idaho
        View My Photos
        Local Time:
        10:53 PM
        I guess what we need is a copy of an older B&M catalog that lists the darn thing
      • etngeorge
        54
        8
        Jul 24, 2013
        Dandridge,Tn
        Local Time:
        1:53 AM
      • MoparLeo
        367
        187
        Feb 10, 2016
        Local Time:
        10:53 PM
        The B&M # 10242 I the flex-plate that I have in my Challenger. 5.9 Magnum Crate engine from Mopar Performance with a 727 small bell housing.
      • 68coupe
        68coupe Well-Known Member
        509
        56
        Aug 23, 2013
        3
        Local Time:
        1:53 AM
        THIS is a flexplate from a 98 5.9 magnum (First picture). The 360 LA flexplate is weighted differently. A 5.2 is not weighted (second picture).
      • dusted
        dusted FABO Gold Member FABO Gold Member
        262
        206
        Sep 24, 2006
        Creedmoor, NC
        Local Time:
        1:53 AM
        I agree to just use the stock magnum flexplate. Funny that this popped up, I just bought this from Summit racing yesterday. I’m on the HotRod powertour and our hotel was almost across the street
      • Bobzilla
        Bobzilla Well-Known Member
        415
        270
        Aug 10, 2017
        Livonia, Michigan
        Local Time:
        1:53 AM
        Hey dusted, what is the number stamped into that flexplate? I think I read 10236 on the sticker, but it's a little blurry when I zoom in on the picture.
        10236 is for an LA 360 external balance, not a Magnum 360. Still a good score though.
      • dusted
        262
        206
        Sep 24, 2006
        Creedmoor, NC
        Local Time:
        1:53 AM
        It’s 10236
