Woodward
This was my Spare Engine
Dropbox - 360 MAGNUM - Simplify your life
It's a 1994 (NEVER IGNITION STARTED) Not Re-conditioned, stock spec, NOS-360-Magnum. Pictures are in Drop Box link.
It's a crate motor…but not quite. It’s just the untouched Bare Block, Rotating assembly, and (2) complete heads, that’s all. No pan, manifold, WP, rocker covers, cam/gears or OP.
So you’re free to do what you want! Works best with the Popular Stroker 408 build.
All U need: the crank, rods and oil pan! Oh, and a cam…That’s about it!
No block machining needed for crank clearance.... That’s the beauty of the Magnum block!
I Prefer local pick-up (Auburn Hills, Michigan Area).... But I will ship, and you know the drill on that....
$450 Pretty firm on that.
Cheers! And Thanks for stopping by!
