360 Magnum oil sender, what gauge to use
player1up
orlando FL
So I've got my 360 mag installed and have started hooking up the gauges, but since the Dakota it came from has real oil pressure gauge, what gauge can I use to read the pressure from the stock ( magnum ) sender ? Or should I just T off the sending unit and hook up the sender for the dummy light?
Just put a tee in it, one for your mechanical gauge and the other for the light.
