360 now 408 stroker oil pan still leaks!!
Small Block Mopar Engine
  1. fuzzman
    fuzzman Well-Known Member
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    I have had this motor for ten years. It used to leak at the rear of the motor and I changed the gasket twice and still could not get it to stop leaking. Than this winter rebuilt motor to a stroker 408 and it started leaking in the rear again so I tried to go through and tighten all the bolts now it is leaking on the front seal. Before I take the pan off this winter is there any secrets that anyone has to stop the oil pan from leaking? A one piece ruberized gasket would be nice for our beloved small block's.
    Help!
    Pat Faley
    1967 Barracuda Notchback
    Peoria IL
  2. PanGasket
    PanGasket has cork sides
    4,618
    66
    Mar 16, 2010
    Gainesville, GA
    Local Time:
    3:10 PM
    It sounds like maybe you should just get a new pan? sounds like it is warped.
  3. orange72dart
    orange72dart Well-Known Member
    71
    0
    Jun 19, 2010
    suisun ca
    Local Time:
    12:10 PM
    pull the pan knock the bolt hole back, you might have over tighten them. use a good cork gasket set and clean the pan and block. apply a good skincoat of RTV let set sould be ok O72D
  4. 73Scamp318
    73Scamp318 Well-Known Member
    303
    3
    Apr 3, 2009
    Waterloo, IA
    Local Time:
    2:10 PM
    Are you running a PCV valve? If not, try it out. If you are, change the valve. I'm thinking that you're having pressure building up in the crankcase, pushing oil out of the crank and pan seals.
  5. illcuda65
    illcuda65 Well-Known Member
    203
    6
    Aug 12, 2010
    normal, illinois
    Local Time:
    2:10 PM
    Fuzzman-
    What machine shop did your stroker work? I am interested in stroking my 318 and could use some advice...
  6. 340mopar
    340mopar Sorgermotorsports
    3,676
    11
    Jan 25, 2006
    Soap Lake, WA
    Local Time:
    12:10 PM
    There is a one piece rubberized pan gasket available for a 360 small block, I have one. I bought it some years ago. I can't remember were I bought it. It may be an MP part.
    Chuck
  7. HemiEd
    HemiEd Well-Known Member
    1,181
    22
    Nov 3, 2006
    Tablerock Lake
    Local Time:
    2:10 PM
    Great point, this is often overlooked. I just had the same issue on my new little roller 318, changed the PCV valve, leak stopped.
    If you run a HV oil pump, it even makes it more difficult on some of the sealing.
  8. LETSRACE
    LETSRACE Well-Known Member
    219
    20
    Jul 27, 2009
    Near Chicago
    Local Time:
    2:10 PM
    Use black RTV on all oil gasket surfaces. I had the same problem but it turned out the header was blocking the valve cover from sealing in the back near the fire wall and when I launched a small stream of oil was running down the space between the head and the block but looked like the oil pan was leaking. I felt like an idiot after I found it but would have bet money the rear seal on the pan was leaking.
  9. 71dustar
    71dustar Well-Known Member
    1,060
    5
    Nov 14, 2007
    Fountain Hills, Az
    Local Time:
    1:10 PM
    this is funny cuz i have a slight oil leak but from the front of the pan on my 408. for right now ill live with it since id rather keep the car on the road. let us know how it goes though cuz ill have to do the same.
  10. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    Chenoweth speed and machine I highly recommend them. They have a very shop and you can read about them in Mopar Muscle they placed second in the engine building contest for building a big block. They are in this years contest to build a killer small block.
  11. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    I did put a new pan on it and I had the same problem and when I put the new gasket on the new pan I also checked to make sure all the holes were straight and not pushed in.
  12. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    I still have the original pcv valve and I'm planning on putting it back in. I picked up a chrome one from a speed shop this summer and have been using it and that might be one of the problems. Thanks
  13. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    I will pick up some black RTV and give it a try when I change out the gasket this winter. I use the black wrinkle mopar performance valve covers and I had a problem before with the valve covers leaking using the cork gaskets so, I went with the rubberized ones and it solved my leaking valve cover gasket problems. Thanks
  14. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    I may try that and see if that solves it. thanks .My next project car is a 69 rag top red with a white top: is yours a 68? Nice Car!
  15. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    I'm also running a stock Oil pump but, with high oil pressure at 1000 rpm I'm running 45LB and at 3000rpm I'm up to 60 to 80lb. I have good oil pressure.
  16. bluedart
    bluedart It's not B3! It's UU1!
    94
    0
    Mar 5, 2009
    Lynnwood
    Local Time:
    12:10 PM
    Rear main?
  17. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    Front and the rear main
  18. crazy 340
    crazy 340 Well-Known Member
    802
    33
    Jan 6, 2008
    quebec canada
    Local Time:
    3:10 PM
    are you sure it aint the rear main seal
    have the same problem and it end up being the rear main seal
  19. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    I just had the motor rebuilt this last winter so I know that the rear main seal was changed.
  20. 1wild&crazyguy
    1wild&crazyguy Banned
    7,993
    178
    Jul 11, 2009
    Surrounded by mopar
    Local Time:
    2:10 PM
    Not sure if someone has said this...but when you line hone the mains, the pan end seals are...too long and like to buckle and leak...
    It all depends on how much was honed out, usually only .005 or so but who knows what they did, and how many times.
    If you see the seal bulging out just a hair...thats a good indicator.
  21. dodge freak
    dodge freak Well-Known Member
    3,991
    35
    Nov 5, 2006
    Too close to Detroit, lol
    Local Time:
    3:10 PM
    What are you talking about?? The seal rides on the main cap and the block rails, how would line honing change that? Maybe I am not getting what you mean?
  22. fuzzman
    240
    22
    Dec 23, 2009
    East Peoria IL
    Local Time:
    2:10 PM
    You know now that you said that the front main in the middle where the oil is leaking the rubber is pushed outward just a tad and the paint isn't on that part of the seal anymore. Right at first the rear started leaking just enough that when I drove it oil would coat the bottom of the dust shield on the trans. I asked the motor builder about it and he told me to tighten up the pan bolts so i have a little at a time. Than I notice another oil spot on the garage floor and sure enough the front started leaking and just like you said it looks just like the middle of the seal has a slight bulge where the paint is gone and you can see the blue ATV sealer showing. It seams to leak more when the motor is running, because it is right behind the fan and it blows it all over the front of the oil pan. I looked up the torque value of the oil pan and it says to torque them to 15 ft lb which translates to 180 inch lb. I have a inch lb torque wrench but I haven't gone that route yet to check them with a torque wrench. So what is the answer if the rubber gaskets are to long? Can you trim them down? or use alot of sealant on the ends? My plan is to try this winter and take the oil pan off and change the gasket and try a Felpro(rubberized) or a Milodon (crush proof) Gaskets. Sorry for the long post.
    Pat Faley
    67 NB Barracuda S Clone
    Peoria IL
