Babyblue66
Cool dude
Here it is with the Edelbrock 600. AF ratio is off with this carb too.
Awesome. Nice build. I like the idea that you got good power and torque with stock heads, mild cam and under 9.0:1 cr. What would you recommend to get one horsepower per cubic inch?It has manual brakes
Put a performer RPM on it.Awesome. Nice build. I like the idea that you got good power and torque with stock heads, mild cam and under 9.0:1 cr. What would you recommend to get one horsepower per cubic inch?
Yes sir. That was the 71 BOSS 351. That was kinda the "last hoorah" for Ford.I remember too well my 351C Ford, built in the 70s, 11:1 compression, 4V iron factory heads, big cam, etc. Ran like a scalded cat on a cool day, but always on the edge of detonation and usually at 200-210*, even in cooler weather. Helluva lotta fun though, when it wasn't eating transmissions at least.
Yes sir. You summed it right up. It's all in the matching parts.It really doesn't take much to build a strong engine. Just the right combination and a little porting. Thanks for all of the positive feedback.
There's nothing in the WORLD wrong with that. She's gonna have a good time with it.Here it is with the Edelbrock 600. AF ratio is off with this carb too.
I bet with the rpm and some carb tuning, (fatten up that one side, and slightly lean out the other) that would exceed 1hp/cu in pretty easily. Assuming the dynos widebands were accurate. Nice street engine.Put a performer RPM on it.
What head gasket thickness did you use?I built this for a lady's 71 Duster. Her old 360 was a turd. She also requested it "sounds good".
8.8 to 1 using speed pro H405CP pistons
2.02 1.60 stainless valves
Stock replacement rockers, shafts, and pushrods
J heads with a little pocket porting
Hughes 2336 Whiplash cam
Performer intake
Recurved old Mopar Performance distributor
With my 750 Holley HP it made
353 hp
388 ft lbs
Using her 600 Edelbrock it lost about 10hp and torque.
Ignore that little curve at the beginning of the pull. It has something to do with loading the dyno.
Standard fel pro. .040What head gasket thickness did you use?
Thanks. I like the combination that you used. Thanks for sharing that with everyone and the dyno read outStandard fel pro. .040
No problem. I like seeing different engine combinations on the dyno. I know there's a lot of engines put together with the wrong parts, so I don't mind helping somebody make informed decisions.Thanks. I like the combination that you used. Thanks for sharing that with everyone and the dyno read out
I do have a video but I'm not sure how to post it.Or may be an Air Gap. It will still be a nice streeter and another 10 horsepower would barely be noticeable. Any videos?
Yes, combination and tuningIt really doesn't take much to build a strong engine. Just the right combination and a little porting. Thanks for all of the positive feedback.
You have to post it on You tube or wherever and then post the link.I do have a video but I'm not sure how to post it.
Flatter but less.Only a 10HP/10TQ difference between a shitty 600 Edelbrock and a High Performance 750 Holley?
The Torque curve looks a lot flatter with the Edelbrock.
Flatter but less.
I guess I look at it differently.
I see it as...... even on a mild 350hp street engine that’s barely using 500cfm of air...... it still made 10ft/lb and 10hp more.
We changed the needles and richened it a little, there wasn't really any change. Every last hp wasn't needed. It'll run good and the jetting will be different anyway sucking in 190 degree air from the radiator.Here's the breakdown in difference between the 750 and 600 on TQ:
3400- 5
3500- 1
3600- 0
3700- 1
3800- 3
3900- 6
4000- 9
4100- 10
4200- 11
4300- 11
4400- 11
4500- 11
4600- 9
4700- 8
4800- 7
4900- 6
5000- 6
5100- 6
5200- 7
5300- 6
5400- 7
5500- 8
5600- 8
Not really a big difference is it. Remember its a 600 VS and a 750. Did the Edelbrock still have the choke attached and did they try different jetting and rods on the 600?
The RPM would probably bring the peak HP up to around 370, maybe a little more.Put a performer RPM on it.
Yes it had a choke. If this was a 450 hp engine the difference would be more dramatic. Who said a 600 Edelbrock is junk?Here's the breakdown in difference between the 750 and 600 on HP:
3400- 3
3500- 1
3600- 0
3700- 1
3800- 2
3900- 4
4000- 7
4100- 8
4200- 9
4300- 9
4400- 9
4500- 9
4600- 8
4700- 7
4800- 6
4900- 5
5000- 6
5100- 6
5200- 6
5300- 6
5400- 7
5500- 8
5600- 9
Not really a big difference here either. Remember this a junk 600 Eddie vacuum secondary vs a High Performance Holley 750 Double Pumper I assume. Not only is there a big difference in design and quality but raw CFM. That big dollar carb sure made a big difference. This should get some people fire up no doubt......
Did the 600 still have the choke attached?
