1. 1973Duster383
    1973Duster383 Well-Known Member
    103
    69
    Oct 25, 2017
    Texas
    Local Time:
    11:19 AM
    It has been a long time since I have had the time to log in and chat about the progress of my build. So long that I lost my login information for my old account, so I started a new one. I am using a new email now and no longer have a way to recover my old login.
    My car is a 1973 Plymouth Duster that currently has a 318 2bbl/auto. It is very boring to say the least. Car has a Reilly Motorsports 4 link in the rear, with a Reilly Motorsports front end currently on order. The car is going to be a street machine/drag car on very limited occasions. Just looking to beat on my buddies with fox bodies and camaros.
    My 383 is .060 Over, has a steel 3.75" crank from 440 Source, eagle H Beam rods, Flat top diamond pistons with a 1.340 compression height vs the standard 1.320. Diamond only charged $56 to move the pin height, which saved us from having to deck the block further than a clean up pass.
    Heads are currently on order as well from Modern Cylinder head. They are going to CNC port a set of 440 Source heads to Max Wedge port, and install the correct springs to my camshaft, and also install a set of tool-steel spring retainers/locks. Intake manifold is going to be a Victor 383 port matched to the max wedge dimension on the head.
    Camshaft is going to be a Comp Cams Hydraulic roller, 23-713-9
    .549/.544, 242*/248*, 110*
    I am not sure which rocker arms I will be going with as of yet. Nor the carburetor size, or headers.
    I would have loved to run trick flow heads, or Edelbrock heads, but the a/c bracket that I am going to run from Bouchillon that locates the compressor where the power steering pump normally resides, will not clear those heads. It gets very hot here in South Texas!
    • Like Like x 3
    • Bobzilla
      Bobzilla Well-Known Member
      507
      328
      Aug 10, 2017
      Livonia, Michigan
      Local Time:
      12:19 PM
      Color combination we don't see often up north and and an engine choice that I don't see often either. This will be a very fun driver with plenty of power. I definitely like this one. Keep the updates and photos coming.
    • 1973Duster383
      103
      69
      Oct 25, 2017
      Texas
      Local Time:
      11:19 AM
      Thank you, the car currently has less than 25,000mi. I am the 2nd owner and looking forward to tearing into it. I have all of the paperwork from the dealership, and two owners books, and two pamphlets that display the options available for 1973
    • AndyF
      AndyF Well-Known Member
      1,267
      962
      Feb 23, 2009
      Oregon
      Local Time:
      9:19 AM
      Sounds good except for the Max Wedge port size in the 440 Source heads. That modification will give you nothing but trouble. There isn't a valley pan gasket that fits the larger port size and you can't really port a Victor intake to Max Wedge size so that plan isn't going to work. Stick with the standard port size and you'll have plenty of power.
      • Agree Agree x 3
      • Thanks! Thanks! x 1
      • Fisher
        Fisher Old Guy with a Cool car.
        1,804
        734
        Jul 22, 2012
        Regina Sask Canada
        Local Time:
        11:19 AM
        I built that same engine pretty well. 383 with steel 440 crank, Eagle rod 10.0-1 compression with Diamond flat top pistons, Eddy rpm performer heads and matching intake. All Out of the box. Lunati solid lifter cam .544/.566 .243/.251 @.050 AED 750 HOM carb will flow to 830 cfm, motor only used 638 CFM on the dyno. 1-3/4 TTI header as they dont make a 1-7/8 for a big block A body. 32 total timing, pump gas made 525 hp and 552 tq, has good manors runs nice on the street with 3.73 gears and a 3500 stall.
        • Like Like x 1
        • Fisher
          1,804
          734
          Jul 22, 2012
          Regina Sask Canada
          Local Time:
          11:19 AM
          • Like Like x 5
          • Fisher
            1,804
            734
            Jul 22, 2012
            Regina Sask Canada
            Local Time:
            11:19 AM
            Comp rockers.
            • Like Like x 2
            • harrisonm
              harrisonm Well-Known Member
              2,035
              1396
              Jan 16, 2005
              Topeka, KS
              Local Time:
              5:19 PM
              Wow. I am intrigued. All you ever hear about is stroked 340s, 360s, 440s, and 426 hemis. I don't believe I have ever heard of a stroked 383. When do you think it will be running? I can't wait for more detail. Does it require any special parts to put a roller cam in a 383?
            • Ottmundr
              Ottmundr 68 Fastback
              4,312
              5900
              Oct 5, 2012
              Sonoma
              Local Time:
              9:19 AM
              I am pretty sure that younggun2.0 did a stroked 383.
            • famous bob
              famous bob mopar misfit
              12,530
              3481
              Aug 14, 2011
              okla
              Local Time:
              11:19 AM
              -----------THIS !!!!!
              • Agree Agree x 2
              • 1973Duster383
                103
                69
                Oct 25, 2017
                Texas
                Local Time:
                11:19 AM
                Sheldon! It's me, your buddy David down in TX!
              • Fisher
                1,804
                734
                Jul 22, 2012
                Regina Sask Canada
                Local Time:
                11:19 AM
                Oh shit. HeyDavid, hope your doing well. I will have to call you.
                • Like Like x 1
                • roccodart440
                  roccodart440 Well-Known Member
                  5,099
                  4071
                  Apr 19, 2010
                  Local Time:
                  12:19 PM
                  I'd go with a 950 Quick fuel
                  • Like Like x 1
                  • IQ52
                    IQ52 Well-Known Member
                    2,311
                    1546
                    Jul 30, 2011
                    Idaho
                    Local Time:
                    10:19 AM
                    Yep, they may be able to take the Super Stealth out to max wedge but it isn't going to run any better than a well done standard Stealth head. I've done a lot of testing on both those heads.
                    • Thanks! Thanks! x 2
                    • Like Like x 1
                    • fishmens67
                      fishmens67 Well-Known Member
                      5,574
                      2390
                      Nov 10, 2012
                      idaho
                      Local Time:
                      11:19 AM
                      Nope, he stroked a 400 to 470.
                    • jamesdart
                      jamesdart Well-Known Member
                      1,559
                      46
                      May 6, 2007
                      Local Time:
                      11:19 AM
                      We built the 431 for my dart in 2000. I went 11s with a Torker, 1 3/4 Headers, and Unported 906 Heads. I Thought It Worked Pretty Good.
                      • Like Like x 1
                      • 1973Duster383
                        103
                        69
                        Oct 25, 2017
                        Texas
                        Local Time:
                        11:19 AM
                        Slight change of course. My heads had not been cut on yet, so I will be getting the standard port CNC heads, and a Torker intake port matched and such. All other parts to remain the same. Considering the Holley Terminator EFI system now. Thanks for the input on the MAX Wedge ports not being ideal for my application. I am ignorant and just wanted BIG EVERYTHING
                        • Like Like x 2
                        • Agree Agree x 1
                        • 1973Duster383
                          103
                          69
                          Oct 25, 2017
                          Texas
                          Local Time:
                          11:19 AM
                          • Fisher
                            1,804
                            734
                            Jul 22, 2012
                            Regina Sask Canada
                            Local Time:
                            11:19 AM
                            Bigger is not always better contrary to popular belief. Even applies to breasts. HAHAHA. Big flow numbers look nice, but are not generally the answer for a street driven car. If your leaving the line on the trans brake at 5500 rpm then yeah, but for the street, smaller ports higher velocity and more air speed make more bottom end and midrange torque.
                            • Like Like x 2
                            • roccodart440
                              5,099
                              4071
                              Apr 19, 2010
                              Local Time:
                              12:19 PM
                              This is kind of BS.. Yeah, max wedge ports etc, yeah, some truth to that, but look at the modern small block street stuff that flows 300-400cfm from .450 lift and up. Flow numbers equal power, plain and simple. Velocity is important too but let not pretend low flow numbers are the hot ticket in a street car.
                              This is why a modern small block makes 425hp stock.
                            • AndyF
                              1,267
                              962
                              Feb 23, 2009
                              Oregon
                              Local Time:
                              9:19 AM
                              Just copy my stuff. I used a Trick Flow intake (much better design than the old Torker) and then added bungs for EFI. This setup will bolt right on your stroked 383.
                              • Like Like x 4
                              • famous bob
                                12,530
                                3481
                                Aug 14, 2011
                                okla
                                Local Time:
                                11:19 AM
                                Andy, is a trickflow intake shorter, or taller than a victor? same? I heard the trick f. was a direct knock off .
                              • 1973Duster383
                                103
                                69
                                Oct 25, 2017
                                Texas
                                Local Time:
                                11:19 AM
                                going to order pushrods soon, any reason why 3/8 are a must? seen several high powered ford and Chevy combos that are using 5/16. Just curious why 3/8 seem to be the only way for Mopar Big Blocks??
                              • EchoSixMike
                                EchoSixMike Well-Known Member
                                258
                                83
                                Nov 20, 2013
                                Chicago
                                Local Time:
                                11:19 AM
                                Depends on spring pressure and length. 5/16" is fine for most flat tappet stuff, particularly with a shorter low deck block. S/F....Ken M
                                • Like Like x 1
                                • 1973Duster383
                                  103
                                  69
                                  Oct 25, 2017
                                  Texas
                                  Local Time:
                                  11:19 AM
