383 Combo Suggestions
Big Block A body Tech
  1. 69dodgedart360
    69dodgedart360 Well-Known Member
    266
    38
    Oct 8, 2006
    Milpitas
    Local Time:
    9:17 AM
    I am just getting ready to start building a 383 for my 69 Dart. I have read tons of articles about a 383 in an A Body but wonder if my build will meet my expectations. I want to run mid-low 12s and this is what I have in mind.
    383 .030 9.5:1
    Stock OOTB Edelbrock Heads
    Edelbrock manifold
    Comp XE274
    750CFM Holley
    Schumacher Headers
    727 with Transgo Shift Kit
    3800RPM Turbo Action Converter
    3.91 gears
    Does anyone have a similar hydraulic cammed combo with real world average joe dyno or quarter mile results?
    P.S. I am a peasant so no I will not be able to afford a stroker crankshaft for this build lol.
  2. rumblefish360
    rumblefish360 So close, yet so far away
    36,941
    8771
    Jun 21, 2005
    New York, on a Island
    Local Time:
    10:17 AM
    You’ll have to sift through the posts as it contains all engines, but I think you’ll find an answer in that “How to run 12’s & how I did it!” Thread.
    Post your 12 second small block combos
    :thumbsup::steering:
  3. dukeboy_318
    dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
    36,212
    13507
    Jan 19, 2007
    la la land
    Local Time:
    10:17 AM
    shaving weight will help ya a bunch too.
  4. ir3333
    ir3333 Well-Known Member
    4,466
    1049
    Jun 1, 2008
    ontario,canada
    Local Time:
    9:17 AM
    do you already have the engine and parts you listed?
  5. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    17,336
    5781
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    9:17 AM
    At your elevation, practically in the water, low12s should be easy. At 3400#Wet, you only need about 350hp.And the 388 combo you detailed should get you there.
    Getting the 60fts down, is not so easy and you could see .4 to .7 second lost on the launch, which could take another 20 to 40hp to compensate for, depending on just how slow the 60ft actually is. But even then, worst case is ~390 hp.
    .............. but IMO,that 9.5Scr is gonna handicap you.My best advice is to jack the pressure up waaay higher than you think it needs. At just 9.5Scr, with alloy heads , IMO, yur leaving a lot of power untapped. With more cylinder pressure, you shouldn't need the 3800, which might, if it matters, make a sweeter streeter.
    xxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxx
    Just for comparison;
    My 3.58 stroke Eddy-headed 360 has happily burned E87 at up to 185psi, the highest I tried. This combo (see Sig,below) went 93 in the Eighth, which the Wallace Calculator translates to 115 in the quarter, which translates to from 12.0 to 12.6 depending on the 60ft, mine was 2.4x, on rollerskates, and lousy starter box.
    • Agree Agree x 1
    • halfafish
      halfafish 66 Valiant, hot-rod in training FABO Gold Member
      965
      779
      Aug 14, 2016
      SW Washington
      Local Time:
      7:17 AM
      :popcorn:
    • PRH
      PRH Well-Known Member
      1,448
      2154
      Dec 14, 2018
      So. Burlington, Vt
      Local Time:
      10:17 AM
      383’s with good heads can make power pretty high in the power band.
      You’re not going to allow that to happen with a hyd cam(certainly not that hyd cam).
      What you’ve outlined is a pretty good package overall....... I’m just saying you’re going to run into the wall at the point where the lifters give up....... and that could easily be at a point in the power band that’s lower than where the rest of the combo could peak.
      I agree with the idea of trying to get the CR up.
      • Agree Agree x 1
      • 383Scampman
        383Scampman Well-Known Member
        1,516
        743
        Nov 24, 2013
        New Hampshire
        Local Time:
        10:17 AM
        Follow AJ/FORMS advise . He's right there . Remember the 350 h.p.number that he recommended is at the tire . Maybe another 20 h.p. just to be safe
        • Agree Agree x 1
        • 69dodgedart360
          266
          38
          Oct 8, 2006
          Milpitas
          Local Time:
          9:17 AM
          Thanks for the replies.
        • MoparPalm
          MoparPalm Member
          5
          18
          Oct 20, 2019
          Greensburg, Pa
          Local Time:
          10:17 AM
          I run a 383 in my duster. 71 block with Keith Black pistons, stock 906 iron heads, torker intake 750 Holley dp, .507/.510 hydraulic cam with a 3800 stall and 4.56 gears has gone 12.33@107 for reference
          • Like Like x 1
          • Thanks! Thanks! x 1
          • Bighead440
            Bighead440 Well-Known Member
            212
            139
            Jun 18, 2017
            Milledgeville, Georgia
            Local Time:
            10:17 AM
            I budget-built a '77 cast crank 400 from a Newport using the complete engine with a deglazed bores ring/ polished crank bearing job, good valve job and some select milling. I milled the 452 heads .060" on the deck and .072" on the intake face (so any unmilled intake would fit perfectly) to up the compression substantially. I also used the .018" shim head gaskets, and the pistons were whatever abysmal negative deck they came with. Used drop-in Crane single valve springs (roughly equivalent to Comp 911 springs, I had them laying around) and a Comp Cams "Dual Energy" 275 cam (still available, listed in "specialty cams" section of the catalog) with 219/235*@.050" duration and .462/.482" lift, 110LSA. With a DP4B intake, 750 AFB carb and HP manifolds with full 2.5" exhaust and Hooker short turbo mufflers it was a beast (at least per dollar)!! I had it in a Challenger with 3.23 gears and a factory 11" hi-stall converter (2400rpm?), and people swore it was a 451. Sounded lopey but pulled from pretty much idle to 6500rpm effortlessly. I love that combo!!!
            • Mr. Sinister
              Mr. Sinister Devastation Manager
              728
              375
              Mar 3, 2017
              Lenox, Mich.
              Local Time:
              9:17 AM
              I had a 68' Satellite street car 71' cast crank 383 .030 over flat top 9.0-1 pistons 906 UNPORTED iron heads Crane HMV 278 cam .467 int. .494 exh if I remember correctly 10" 2800 stall converter Edelbrock dual plane 650 Holley dual point Accel distributor 4:56 ring and pinion Hooker headers
              Best pass was 12.68 at 108 mph fun car
              I sure miss that old air craft carrier.:(
              383 should easily get you into the 12s:thumbsup:
              • Like Like x 1
              • 69conv
                69conv error 401 FABO Gold Member
                2,511
                1851
                Jan 27, 2013
                Motor City
                Local Time:
                9:17 AM
                traction
              • PRH
                1,448
                2154
                Dec 14, 2018
                So. Burlington, Vt
                Local Time:
                10:17 AM
                Pump gas 383, ported big valve 452’s, rpm intake, hp750 carb, 1-7/8” headers.......solid cam:
                • Like Like x 2
                • Mr. Sinister
                  728
                  375
                  Mar 3, 2017
                  Lenox, Mich.
                  Local Time:
                  9:17 AM
                  image.jpeg The Satellite A.K.A. The Aircraft Carrier
                  The previous mentioned MILD 383 12:68@108 mph - check out the lift.
                  • Like Like x 4
                  • PRH
                    1,448
                    2154
                    Dec 14, 2018
                    So. Burlington, Vt
                    Local Time:
                    10:17 AM
                    Nice.
                    I’m kinda partial to them.
                    That’s what my heap is.......a 68 Satellite.
                    • Like Like x 1
