moparstud440
For those that have used either a 440 source or Monlar 4.25 crankshaft in a 400 block, did you have to Chamfer the main bearings? If you didn't, who's main bearing did you use?
They seem to be the only game in town
Main Bearings-440 Source
Hughs engines -------------
Yes they do need to be chamfered
Who's crank and main bearings did you use?Mine didnt !!
Maybe, maybe not. I always order chamfered bearings when building a stroker engine since I'd rather be prepared than find out too late that I need them.Thanks guys, but I'm wanting to know DO the bearings need chamfered?
I used Molnar crank and rods in my 400 block and did not have to chamfer bearings. I used Clevite P series 876p full groove bearings. Everyone said i would have to chamfer, but i seen no issues on assembly or now with 4 seasons on the motor.For those that have used either a 440 source or Monlar 4.25 crankshaft in a 400 block, did you have to Chamfer the main bearings? If you didn't, who's main bearing did you use?
Isn’t your a RB block. Totally different than a B block. KimMine didnt !!
