[WANTED] 4 Barrel Air Cleaner Bottom
crashcaptn
1965 Dodge Dart GT
San Diego, CA
Rating - 0%
0   0   0
Looking for a 4 barrel carb air cleaner bottom piece. I just scored a top part and need the bottom. Just the round circle with a hole in it.. Even if someone out there has a chrome or black one, dont matter - either will do for the stock 12 inch one.
Even willing to trade? I have a bottom for a 1 or 2 barrel. its chrome. I'm sure someone would be stoked to have it
Cheers
Jeff
Why not just go to Jegg’s or Summit and buy a really cheap 4 bbl air cleaner (12”)
And throw away the top. I’ve done it before and it’s like $20
Just an option.
Yeaaaah. i was thinking of just going that route. measured that a 10-10.5" would work just fine
Depends what 4bbl carb you're using...if it's an early AFB ('mid '60's) then you need the smaller hole base...4 7/8" IIRC....later Carter/Eddy or Holley, you can go the parts store route.
yup! Holley here. its a good idea - i'll look up some cheap as all hell holley type air cleaner and snag the base off that..
