4 bolt 340 block
Small Block Mopar Engine
  1. moparraceman
    moparraceman Well-Known Member
    1,490
    193
    Aug 1, 2010
    mansfield ohio
    Local Time:
    9:29 AM
    did mopar ever make a 4 bolt 340 block ? value ?
  2. jimjimjimmy
    jimjimjimmy lobsterman FABO Gold Member
    4,423
    1211
    Nov 2, 2010
    p. e. i.
    Local Time:
    11:29 AM
    yes and it depends which one , there's the x block and r3 blocks and maybe more could be had with 4 bolt mains , but no passenger car 340 were 4 bolt , the x and r3 are race blocks .
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      61,630
      33586
      Jun 7, 2010
      Georgia
      Local Time:
      10:29 AM
      I think some of the TA blocks had 4 bolt mains. @Alaskan_TA can tell you for sure.
      • Disagree Disagree x 2
      • Go Mango
        Go Mango Never enough beer...
        699
        1087
        Jun 3, 2018
        Avon, Indiana
        Local Time:
        10:29 AM
        I'm pretty sure the T/A blocks just had extra webbing added so that aftermarket 4 bolt caps could be added.
        But your right, Rob, Alaskan TA is really the guy that would know.
        • Agree Agree x 5
        • brian6pac
          brian6pac Well-Known Member
          4,688
          3167
          Nov 15, 2016
          N.E.Ohio
          Local Time:
          10:29 AM
          No the T/A's did not have 4 bolt mains but they did have thick webs for 4 bolt mains if you wanted to install them.
          • Agree Agree x 7
          • RustyRatRod
            61,630
            33586
            Jun 7, 2010
            Georgia
            Local Time:
            10:29 AM
            I'm probably getting them confused with some of the letter blocks then.
            • Agree Agree x 1
            • moparraceman
              1,490
              193
              Aug 1, 2010
              mansfield ohio
              Local Time:
              9:29 AM
              thanks guys
            • rumblefish360
              rumblefish360 So close, yet so far away FABO Gold Member
              38,283
              9932
              Jun 21, 2005
              New York, on a Island
              Local Time:
              10:29 AM
              All stock blocks are 2 bolt mains. Except.....
              The ‘70 T/A - AAR 340 6 pack engines had the thick/filled in areas that could be drilled and tapped for a 4 bolt application.
              Not all of MP race blocks came with 4 bolt main caps.
              All of the race blocks could be tapped for 4 bolt main caps.
            • stixx
              stixx Well-Known Member
              788
              555
              May 30, 2006
              Southern Germany
              Local Time:
              3:29 PM
              ^^^^^^^^^^^^^^^^ That should be made a sticky.
