4 piston to single piston swap. 72 Demon
Brakes for your Classic Mopar
  1. Woodie
    Woodie Take-off EH!
    458
    136
    Feb 10, 2012
    Ontario
    Local Time:
    4:04 AM
    I Planning on swaping out the factory 4 piston set- up currently on the Demon in favor of a single piston set up I took off of a 73 Dart sport. Reason for this is I have SBP on the front and LBP aftermarket axles on the rear. Are the front spindles the same? Also curious if I use the same factory upper control arms as well. Will the brake proportioning still be the same?
    Thanks.
    • Like Like x 1
    • hemi71x
      hemi71x FABO Gold Member FABO Gold Member
      5,408
      1940
      Dec 22, 2009
      Rancho Cordova, CA
      Local Time:
      2:04 AM
      No, spindles are not the same.
      Two totally different brake designs.
      You will need to change over your upper control arms to 73-76 large ball joint ones, and change your lower ball joints over to 73-76 ones.
      • Like Like x 1
      • Woodie
        Woodie Take-off EH!
        458
        136
        Feb 10, 2012
        Ontario
        Local Time:
        4:04 AM
        Thanks for the info. Need to source a set of upper control arms. I have everything else.
        • Like Like x 1
        • hemi71x
          5,408
          1940
          Dec 22, 2009
          Rancho Cordova, CA
          Local Time:
          2:04 AM
          Search hemi71x in the for sale section of this forum.
          I have a pair of UCA's for sale.
          • Like Like x 1
          • Woodie
            Woodie Take-off EH!
            458
            136
            Feb 10, 2012
            Ontario
            Local Time:
            4:04 AM
            Nice.
            • Like Like x 1
            • RedFish
              RedFish Well-Known Member
              24,030
              2696
              Sep 5, 2007
              Local Time:
              4:04 AM
              There are adapter bushings for the spindle holes that let one use the smaller ball joint and matching upper arm in the larger spindle hole. I haven't used these bushings. I'm not recommending them. FYI only.
              • Like Like x 1
              • Woodie
                Woodie Take-off EH!
                458
                136
                Feb 10, 2012
                Ontario
                Local Time:
                4:04 AM
                Thanks for the input Redfish. Thinking of going aftermarket "Tubular".
                • Like Like x 1
                • Jimacuda
                  Jimacuda Well-Known Member
                  1,699
                  541
                  Nov 10, 2006
                  Phoenix AZ
                  Local Time:
                  2:04 AM
                  ball joint adapter is the way I'd go if the small ball joints and uca bushings are newer. DrDiff carries them.
                  No getting around replacing the lower.
                  73-76 A body lower ball joint, same piece disc or drum.
                  • Like Like x 1
                  • Woodie
                    Woodie Take-off EH!
                    458
                    136
                    Feb 10, 2012
                    Ontario
                    Local Time:
                    4:04 AM
                    Thanks Jimacuda.
                    • Like Like x 1
                    • FredS
                      FredS Well-Known Member
                      876
                      66
                      Feb 13, 2013
                      Arizona
                      Local Time:
                      2:04 AM
                      why not just use Mustang rotors and keep everything you currently have
                      • Like Like x 1
                      • Woodie
                        Woodie Take-off EH!
                        458
                        136
                        Feb 10, 2012
                        Ontario
                        Local Time:
                        4:04 AM
                        Just read that post.. Good read too. :)
                        • Like Like x 1
                        • AJ/FormS
                          AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                          18,018
                          6317
                          Jan 19, 2014
                          South-Central Manitoba,Canada, 900ftelevation
                          Local Time:
                          4:04 AM
                          Sooooooooooo
                          What's wrong with different bps front to rear? I've been doing that for decades.
                          You know those 4-piston calipers are fabulous for a streeter. No sliders to wear out or pins to jam up, and pad replacements take mere minutes. Or hey, if one pistons freezes up in winter, due to moisture, there are still 3 others to get the job done,lol.
                          I really like my KHers. And I'm OK with 14x7s up front and 15x10s out back.
                          As to proportioning, that depends more on what your rear rubber can handle.My P-valve is gutted, and the rear could handle even more pressure.
                          Seems like a lotta work, for what I would call a minor gain.
                          But if you are wanting to run 4 same-size, interchangeable, wheel assemblies; that I can understand.
                        • Woodie
                          Woodie Take-off EH!
                          458
                          136
                          Feb 10, 2012
                          Ontario
                          Local Time:
                          4:04 AM
                          ..I agree with the with your thoughts.. I have Centerlines front and rear. I want to run a set of Cop wheels with 15x6 up front an 15x10s on the rear for a Nasty look. I have a complete set of 73 front discs, spindles minus the Upper Control arms. (I gave them to a friend in need a while back) just seeing what my options are. Also i feel its time to rebuild the entire front end, pull it apart and make it new again.
                        • AJ/FormS
                          18,018
                          6317
                          Jan 19, 2014
                          Local Time:
                          4:04 AM
                          I forgot to mention;
                          I was so busy finding fault with the 73Up stuff, that it slipped my aging mind. The KH stuff has been trouble-free for me to the tune of 17 years and 125,000 plus miles. That's Zero maintenance required.And no, I have never had a moisture issue with DOT5.Nor the so-called compressibility.I do have the Teflon-lined front hoses. Awesome street brakes with the 10 x 2.5s and 295s out back doing a good portion of the work!I have never had a car that braked; better, harder,or in a shorter distance.And I think I may have only ever been in one other comparably stopping street car,since 1969. I think all cars should have bigger tires and harder working brakes, out back. I mean think about what that P-valve is doing. It is preventing the rear from skidding the tires and initiating a spin.Wouldn't more rubber back there have been a better idea? I thought so, and that's partly why I worked so hard to get the bigger boots back there. Well that and spinning out on every turn-under-power, was getting old........lol
                          • Like Like x 1
