4 speed install on 68 Dart, 440 6 pack
Manual Transmission & Clutch Discussions
  1. 808440Dart
    808440Dart FABO Gold Member FABO Gold Member
    18
    32
    May 19, 2017
    Honolulu, HI
    Local Time:
    4:58 AM
    Sharing some pics and info of my 4 speed swap I just did on my 68 Dart. It wasn't very complicated, easier than I thought. Took me a couple months tinkering with it on the weekends. I won't go into details, we all know how it bolts together. I did get really really good at installing and removing the transmission, and real good and taking it apart and putting it back together. The drivers side engine bay is really tight and busy, but it all fits in there.
    It's a blast to drive and got my attention real quick when I took it off the jack stands and made a test run to McDonald's for lunch last Sunday. Never going back to an automatic. Driving it around a bit before I put the carpet and rear seat back.
    Parts:
    Pedals - Good used from a 69 Dart
    Quicktime bell housing - RM6073
    Trans - Very good used A833 from a 71 Duster
    Shifter - Very good used Hurst SS3 complete set up for A body
    Hump - Used from a 69 Dart
    Brewers clutch torque shaft kit - TS252KIT (This kit is the bomb!)
    Brewers 23 spline reseal kit - GS23 (I resealed my trans and zero oil leaks! Not even sweating)
    Release bearing arm - New in box Mopar I bought at a swap meet. Forgot part # but I had to shorten it 1"
    Roller bearing pilot conversion - Forgot part number, bought off eBay.
    Clutch - Napa (Luk) - 10.5/23 spline forgot part # but it's "just to get it going". It will probably be toast by Halloween.
    Flywheel - Good used 10.5/130 teeth that I got resurfaced.
    Flywheel & pressure plate bolts - Factory Mopar ones from ebay.
    Drive shaft - Driveline shop re tubed/lengthened my old one .
    • Like Like x 11
    • Thanks! Thanks! x 1
    • cudascott
      cudascott It’s a sickness!
      1,968
      925
      Jan 11, 2012
      TN
      Local Time:
      9:58 AM
      Killer ride!
      • Agree Agree x 3
      • Dartnut
        Dartnut Don't hate me because i'm beautiful
        11,768
        4834
        Apr 19, 2007
        Southern Alberta
        Local Time:
        7:58 AM
        Cool car!
        I have a few questions:
        What headers are you running?
        How much of a pain was it to get the bell housing centered to the transmission?
        What is the rear end and the gear ratio?
        Thanks,
        Tom.
      • slickchick
        slickchick pedal cars only
        373
        102
        Jul 24, 2010
        maryland
        Local Time:
        8:58 AM
        Big Block !! Six Pack !! Four Speed !!! with Air conditioning, Patina'd out !! Truly the "wolf in sheeps clothing" Super nice ride !!! and Unsuspecting :elmer:
        • Agree Agree x 5
        • Daves69
          Daves69 Well-Known Member
          6,045
          4577
          Feb 20, 2011
          WestOfChi
          Local Time:
          8:58 AM
          Did you need to mod that air cleaner base for AC and wiper motor?
        • rklein383
          rklein383 Well-Known Member
          1,715
          696
          Dec 2, 2005
          Local Time:
          8:58 AM
          When I had a 440+6 in my 69 383-s, no modifications to the air cleaner was necessary for the wiper motor, although it did sit right up against the wiper motor.
          • Thanks! Thanks! x 2
          • Daves69
            6,045
            4577
            Feb 20, 2011
            WestOfChi
            Local Time:
            8:58 AM
            This is where the wiper nose ends up when I have the six pack is on and using a shaker base on my Barracuda. Appears an under hood or fresh air base may have an issue.....
            • Like Like x 1
            • 808440Dart
              18
              32
              May 19, 2017
              Honolulu, HI
              Local Time:
              4:58 AM
              Headers - Schumacher conversion headers. Had to do some minor fab ing to reroute the drivers collector to clear the clutch z bar.
              Bell housing - It comes with two different size centering rings, I think mine took the smaller one. I took the input collar to my friends machine shop and he polished the down OD of the collar so it fit cleanly in the adapter ring.
              Rear - 3.91 with sure grip.
              Let me know if you need any other info.
              • 808440Dart
                18
                32
                May 19, 2017
                Honolulu, HI
                Local Time:
                4:58 AM
                Yes, I made to make two small semi circle cuts to clear the wiper motor and AC compressor.
                • Like Like x 1
                • cudascott
                  1,968
                  925
                  Jan 11, 2012
                  TN
                  Local Time:
                  9:58 AM
                  slap on a three speed wiper setup and no need to cut on an original air grabber/ramcharger air cleaner
                  • Agree Agree x 2
                  • rklein383
                    1,715
                    696
                    Dec 2, 2005
                    Local Time:
                    8:58 AM
                    My air cleaner was a repop.
                    • Like Like x 1
                    • A56
                      A56 MoPar Affliction
                      5,404
                      14274
                      Jun 24, 2014
                      South of the Mason-Dixon Line
                      Local Time:
                      8:58 AM
                      • Agree Agree x 1
                      • Dartnut
                        11,768
                        4834
                        Apr 19, 2007
                        Southern Alberta
                        Local Time:
                        7:58 AM
                        Thanks for the response.
                        Too bad that Shumacher isn't in business anymore.
                        The reason that I was asking about the bell housing is that I knew a guy that had a Lakewood bell housing and it was a real P.I.T.A to get the hole centered to the crank.
                        I take it that you have a small bolt pattern 8 3/4.
                        If you do, don't put sticky tires on it, because it won't last.
                        Years ago, I had to put a Dana 60 in because the 8 3/4s just wouldn't take it.
                        The reason for the questions are that I'm planning to do a similar build in the near future........
                      • DrCharles
                        DrCharles Well-Known Member
                        1,301
                        1133
                        Jun 7, 2012
                        West Plains, Mo.
                        Local Time:
                        8:58 AM
                        What problems did he have?
                        I'm running a Lakewood in my 451 Dart.. it was definitely off-center by a lot (can't remember exactly how much), glad I checked it. So I installed offset dowels (which got it closer but not close enough), then enlarged the dowel holes in the Lakewood slightly, lined it all up and welded 1/4" thick washers (which were a snug fit on the dowels) onto the bellhousing flange. Just about zero runout after that :)
                        Of course, if the block had been in the car, it would have been much more of a PITA :rolleyes:
                        • Like Like x 1
                        • Dartnut
                          11,768
                          4834
                          Apr 19, 2007
                          Southern Alberta
                          Local Time:
                          7:58 AM
                          Pretty much the same problem and the same solution that you came up with.
                          The engine was in the car which made it worse!
                          So, the Quick Time was more centered to the crank than the Lakewood?
                        • plumkrazee70
                          plumkrazee70 Well-Known Member
                          3,065
                          941
                          May 5, 2013
                          Medford, Oregon
                          Local Time:
                          8:58 AM
                          The shifter is awfully close to the drivers seat, is that normal?
                        • Daves69
                          6,045
                          4577
                          Feb 20, 2011
                          WestOfChi
                          Local Time:
                          8:58 AM
                          Pretty much. Mine in 1 and 3.............
                          2 and 4.............
                          • 808440Dart
                            18
                            32
                            May 19, 2017
                            Honolulu, HI
                            Local Time:
                            4:58 AM
                            Yup, small bolt pattern 8.75. I have a set of Yukon big bolt axles for it, but I'm thinking just go Dana.
                            • Agree Agree x 1
                            • 808440Dart
                              18
                              32
                              May 19, 2017
                              Honolulu, HI
                              Local Time:
                              4:58 AM
                              I thought the same thing, but that's where the hump ended up and it looked sort of looked like it's in the correct spot. The seats are freebies from a 69 Cuda so I'm not sure if they are wider than Dart seats.
                              • Like Like x 1
                              • 808440Dart
                                18
                                32
                                May 19, 2017
                                Honolulu, HI
                                Local Time:
                                4:58 AM
                              • Dartnut
                                11,768
                                4834
                                Apr 19, 2007
                                Southern Alberta
                                Local Time:
                                7:58 AM
                                You'll never regret going with a Dana rear end.
                                It's good insurance and it looks good doing it!
                              • CRUZE 418
                                CRUZE 418 FABO Gold Member FABO Gold Member
                                1,067
                                468
                                Mar 11, 2019
                                Illinois
                                Local Time:
                                8:58 AM
                                I would like to race you , changing spark plugs. There's just no way that I would ever put a big block in an a body, unless it was a Hemi, maybe.
                                Good luck and have fun.
