400/450 stroker....Cheap parts, lotta work.
Big Block A body Tech
  1. IQ52
    IQ52 Well-Known Member
    2,716
    2471
    Jul 30, 2011
    Idaho
    Local Time:
    5:03 PM
    Kinda got the 346 iron heads ready for the KB251 pistons. Flat chamber depths were from .084"-.102" and they are all now .110". The quench pad on the pistons are .260" tall and we'll have to mill about 1/2 that off or rather some .125" with the preliminary measurements.
    Cody and I are having some fun with this engine. Just went and bought the 251's because they were the cheapest stroker piston I could buy. We'll be using rebuilt stock 6.358" 400 rods. They are of course just a teeny bit shorter now.
    • Like Like x 14
    • yellow rose
      yellow rose Overnight Sensation FABO Gold Member
      28,619
      25210
      Jun 19, 2015
      Central Washington
      Local Time:
      4:03 PM
      WOW...that was a ton of work. Looks damn nice.
      • Agree Agree x 4
      • Thanks! Thanks! x 1
      • Hellrats
        Hellrats Just another dumbass
        1,548
        1284
        Jan 24, 2012
        N.E. Ohio
        Local Time:
        7:03 PM
        Nice work. Should be a good running engine.
        • PRH
          PRH Well-Known Member
          3,425
          5055
          Dec 14, 2018
          So. Burlington, Vt
          Local Time:
          7:03 PM
          Wasn’t there a recent post where someone said something along the lines of, “Dad....... just no more iron”.
          • Agree Agree x 3
          • IQ52
            2,716
            2471
            Jul 30, 2011
            Idaho
            Local Time:
            5:03 PM
            Way less pressure and more fun when you are doing it for yourself. We have three more besides this......just for us. A 440 for the Trail Duster hunting rig, and two 383's. One for the 4-wheel drive 1968 Chrysler Town and Country wagon and the other for the 833 4-spd '67 2-wheel drive Coronet wagon.
            • Like Like x 2
            • Agree Agree x 1
            • IQ52
              2,716
              2471
              Jul 30, 2011
              Idaho
              Local Time:
              5:03 PM
              We're using the cheapo 400 6.358" factory rods. I didn't think to measure the rod lengths before the rebuild but they are now.....
              #1) 6.355"
              #2) 6.355"
              #3) 6.357"
              #4) 6.351" from a different engine
              #5) 6.356"
              #6) 6.356"
              #7) 6.357"
              #8) 6.355"
              Probably move them around some and use #4 in the smallest combustion chamber. Lotta work, just like the cheapo 346 iron heads.............
              After we measure all the crankshaft throws and before the balancing, I'll cut the quench pads for each cylinder so there is zero piston to head clearance with no head gasket and then use the 8519PT1 head gasket for .039" clearance. Should be enough.
              • Like Like x 3
              • Agree Agree x 1
              • Bewy
                Bewy Well-Known Member
                1,084
                655
                Jan 1, 2021
                Australia
                Local Time:
                10:03 AM
                What will the final quench be? I did similar about 15 years back, but I had the recesses in the heads machined, didn't do it by hand.
              • RustyRatRod
                RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                77,991
                55511
                Jun 7, 2010
                Georgia
                Local Time:
                7:03 PM
                He told you. .039".
                • IQ52
                  2,716
                  2471
                  Jul 30, 2011
                  Idaho
                  Local Time:
                  5:03 PM
                  Most work was done on a vertical mill with hand touch up.
                • mbaird
                  mbaird mbaird
                  7,473
                  4266
                  Dec 10, 2005
                  boise, Id
                  Local Time:
                  5:03 PM
                  I love the sound of those wagon builds ....I have to get up there someday .
                  • Like Like x 2
                  • Agree Agree x 1
                  • IQ52
                    2,716
                    2471
                    Jul 30, 2011
                    Idaho
                    Local Time:
                    5:03 PM
                    After decking the block all four corners are 9.968"..............
                    This is the test rod of know length, 6.356". I had the press fit pin end honed so the pin will slip in/out and I can test the machined crank (standard 400 mains and .020" under rods) for stroke length on each throw. Any piston I want to use will just slip on and off.
                    • Like Like x 5
                    • 66fs
                      66fs FABO Gold Member FABO Gold Member
                      5,999
                      2551
                      Sep 9, 2009
                      Greenwood, South Carolina
                      Local Time:
                      7:03 PM
                      I have one of those plus others for different engines.
                      • Like Like x 2
                      • Agree Agree x 1
                      • RustyRatRod
                        77,991
                        55511
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        7:03 PM
                        What are you going to do for the difference in rod lengths. I read it, but I'm so dumb I cannot comprendo. Can you stupid it up some?
                      • IQ52
                        2,716
                        2471
                        Jul 30, 2011
                        Idaho
                        Local Time:
                        5:03 PM
                        I have four pistons @ 1.722" CH and four @ 1.723". Once I have checked all the rod throws for stroke length using my test rod and one piston, I can do a dance with rod length, CH, and stroke length to get all deck heights as close as possible. It won't make any difference on the stamped rod number as I may use it in a different cylinder number (i.e. #1 rod in place of #6). Then before the balancing is done I will machine each quench pad for a specific cylinder depending on the deck height. After the dance if #3 piston is .003" lower in the bore than #7, I will leave the quench pad .003" taller on #3 than the pad on #7 piston. I can do it this way because all the flats in the head combustion chamber are all .110" below the head face.
                        Even though the flats are all the same in the heads, the combustion chambers are a little different in cc's. Because rod #4 is so short I may shuffle it to a combustion chamber that is smaller in cc's than the others to attempt to balance the compression ratios from cylinder to cylinder.
                        Still clear as mud right?
                        • Thanks! Thanks! x 2
                        • Like Like x 1
                        • Agree Agree x 1
                        • greymouser7
                          greymouser7 Vagrant Vagabond “Veni Vidi Vici”
                          3,541
                          2799
                          Apr 17, 2010
                          78002 down the road from Atascosa, Texas
                          Local Time:
                          6:03 PM
                          if you didn't do any of that, and kept the rpm maxed at 5500 rpm, it wouldn't matter too much would it? It would affect longevity, and smooth operation, but the bearings wouldn't suffer immediately would they?
                        • RustyRatRod
                          77,991
                          55511
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          7:03 PM
                          Just spitballin.....why not play around with the big end center line and get the lengths equal? index the crank first of course and then even the lengths of the rods with the big end placement. Bad idea?
                        • mbaird
                          mbaird mbaird
                          7,473
                          4266
                          Dec 10, 2005
                          boise, Id
                          Local Time:
                          5:03 PM
                          What is your goal for power production ? What kind of torque curve ?
                        • IQ52
                          2,716
                          2471
                          Jul 30, 2011
                          Idaho
                          Local Time:
                          5:03 PM
                          I don't think it would cause any problems at all.
                          If I had the equipment to do so I would have tried to make them all the same length. However I'm dependent on others to rebuild the rods.
                          I have no idea what this engine will do. I've never built one like this. We'll test it with the stock cast iron intake and HP exhaust manifolds, shop headers and two or three different aluminum intake manifolds.
                          • mbaird
                            mbaird mbaird
                            7,473
                            4266
                            Dec 10, 2005
                            boise, Id
                            Local Time:
                            5:03 PM
                            I guess my question should have been ...
                            What is it going in ? Truck , hotrod , cruiser ?
                            Please post a picture of that 4x4 T&C wagon . I have to see that ...lol
                            • Agree Agree x 1
                            • IQ52
                              2,716
                              2471
                              Jul 30, 2011
                              Idaho
                              Local Time:
                              5:03 PM
                              We've had this original 400 big block '73 Dodge Charger sitting out back with no engine for some 10 years....going in that.
                              Then here is the 4x4 Wagon...................
                              • Like Like x 12
                              • PRH
                                3,425
                                5055
                                Dec 14, 2018
                                So. Burlington, Vt
                                Local Time:
                                7:03 PM
                                Cool wagon.:thumbsup:
                                • Agree Agree x 2
                                • MarPar
                                  MarPar Young Troubadour FABO Gold Member
                                  1,600
                                  3151
                                  Aug 15, 2010
                                  Madigadistan
                                  Local Time:
                                  6:03 PM
                                  I'd use that sucker for the trail rig!! lol
                                  • Agree Agree x 1
                                  • IQ52
                                    2,716
                                    2471
                                    Jul 30, 2011
                                    Idaho
                                    Local Time:
                                    5:03 PM
                                    I've run 2.25"/1.81" valves in factory iron heads before. This time I'm using 2.20"/1.84" valves. I wonder how much cylinder wall to valve clearance I have at .700" lift.
                                    Intake valve..........
                                    Exhaust valve............
                                    As the plan is to run about .550" with a solid flat tappet we seem to be really safe.
                                    • Like Like x 4
                                    • RustyRatRod
                                      77,991
                                      55511
                                      Jun 7, 2010
                                      Georgia
                                      Local Time:
                                      7:03 PM
                                      Well that splains that Lucy!
                                    • RustyRatRod
                                      77,991
                                      55511
                                      Jun 7, 2010
                                      Georgia
                                      Local Time:
                                      7:03 PM
                                      Hay I thought you were too old to bend down for those kinda shots now!
                                      • Agree Agree x 1
