402 Pan to 187 pan - Pick up and windage tray
Big Block A body Tech
  1. CaseyFJ
    CaseyFJ Active Member
    36
    26
    Nov 5, 2019
    Columbus, OH
    Local Time:
    10:17 PM
    Good Morning,
    Switching from a 402 pan over to a 187 pan to shove a 383 in an A-Body.
    Can I use the same pick up and windage try from the 383 with the 402 pan on it?
    Thanks!
    Casey FJ
    • Thanks! Thanks! x 2
    • Daves69
      Daves69 Well-Known Member
      5,738
      4099
      Feb 20, 2011
      WestOfChi
      Local Time:
      9:17 PM
      Per the FSM, the stock PU should touch the pan bottom.
      Dimensions may help ya'.....
      Oil Pan Schematics
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      19,309
      6466
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      9:17 PM
      What year is ur A body. 73 up can use the 402 pan no problem. Kim
      • Thanks! Thanks! x 1
      • CaseyFJ
        36
        26
        Nov 5, 2019
        Columbus, OH
        Local Time:
        10:17 PM
        68 Valiant
      • Daves69
        5,738
        4099
        Feb 20, 2011
        WestOfChi
        Local Time:
        9:17 PM
