1. 1stgen
    1stgen Member
    14
    3
    Mar 24, 2019
    UK
    Local Time:
    7:56 AM
    Hi, I’m in the process of building a 408 stroker (360) with the aim of 500hp. The cam I have is from Hughes SEH4652AL-6 which they put together with stroker kit. This is mainly a street car which is a B body and I was after some advice on the intake choice and is there anybody running this cam on the street? Cheers
  2. stixx
    stixx Well-Known Member
    779
    544
    May 30, 2006
    Southern Germany
    Local Time:
    7:56 AM
    Most important: what cylinder heads are you going to use? Stock or aftermarket?
    • Agree Agree x 1
    • 1stgen
      1stgen Member
      14
      3
      Mar 24, 2019
      UK
      Local Time:
      7:56 AM
      I have Edelbrock RPM heads
      • Agree Agree x 1
      • 1stgen
        1stgen Member
        14
        3
        Mar 24, 2019
        UK
        Local Time:
        7:56 AM
      • 360duster
        360duster Well-Known Member
        1,188
        305
        Nov 23, 2008
        Bavaria / Germany
        Local Time:
        8:56 AM
        what kind of compression and rear gears are you running? Streetable for sure with the right gears / converter….but don´t expect it to be tame and idling at 750 rpm at the stoplight.
        Michael
        • Agree Agree x 2
        • 1stgen
          1stgen Member
          14
          3
          Mar 24, 2019
          UK
          Local Time:
          7:56 AM
          Aiming for 10.9:1 compression and I currently have 3.23 gears
        • stixx
          779
          544
          May 30, 2006
          Southern Germany
          Local Time:
          7:56 AM
          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^This. What he says... you need more gear and a higher stall
          converter with that cam.
        • dragfish
          dragfish Well-Known Member
          79
          19
          Dec 13, 2006
          Local Time:
          1:56 AM
          I run the hughes 3842 solid in my car with 3200 converter and 3.55 gears edelbrock rpm intake 750 HP holley I updated my springs with beehives and run PRW stainless rockers car has a lope and runs real good.Motor is 40 over 360 9.5 compression.
        • 1stgen
          1stgen Member
          14
          3
          Mar 24, 2019
          UK
          Local Time:
          7:56 AM
          Drag fish, how are the 3.55 gears on the open roads?
          Cheers for the comments
        • BrianT
          BrianT Let's go!
          5,505
          1220
          Mar 13, 2007
          Kansas City, Mo
          Local Time:
          1:56 AM
          You're going to need to do some work to those Edlebrock heads to hit the 500 hp mark. The heads are a limiting factor. Here's my build thread...
          408 Build Thread
        • 12many
          12many Well-Known Member
          1,133
          1388
          Dec 14, 2016
          SC
          Local Time:
          1:56 AM
          I know gear choice recommendations can be all over the map, but I originally went with 3.73's on my 410 stroker van, as a compromise, and is a good choice for street/strip, very streetable and best of both worlds but as I'm doing more strip than street now just went ahead with a 4.10 swap. I don't do burnouts on the street anymore at all as all it takes for that is a sneeze and its a stupid long burnout until i let off....but I now run low psi drag radials and do rolling acceleration runs. The pull is phenomenal with all that traction and 4.10's. And cruising at 65-70 mph max isn't bad at all, IMO. I'd recommend doing calculations with rear gears, tire diameter and each trans gear and compare the numbers to best match your intentions.
        • rumblefish360
          rumblefish360 So close, yet so far away FABO Gold Member
          37,789
          9480
          Jun 21, 2005
          New York, on a Island
          Local Time:
          2:56 AM
          What I would do.....
          Port match a RPM intake to the heads which should also be ported. Zero deck the pistons and run a gasket thinner than .050. Use a 1-3/4 header tube into a 2-1/2 exhaust pipe at a min.
          3.23 gears?!?! Ummmm, no....
          3.55’s? Maybe
          Use a first class converter.
        • Valkman
          Valkman Well-Known Member
          875
          268
          Sep 13, 2012
          NC
          Local Time:
          2:56 AM
          If you're goal is 500hp you'll have to give low end torque to get that peak hp at a higher RPM. With a 3.23, it will drive like a pig at low rpm's on the street even with a high stall converter. Ask me how I know.
        • autoxcuda
          autoxcuda Well-Known Member
          6,255
          606
          Apr 6, 2007
          Local Time:
          11:56 PM
          What tire diameters/sizes are you guys running that are suggesting rear end ratios?
          1stgen, What octane of gas are you planning to run. Not sure 10.9:1 is going to run off pump 91 octane.
          Notice dragfish runs 9.5:1
        • A408Cuda
          A408Cuda FABO Gold Member FABO Gold Member
          560
          714
          Mar 5, 2018
          South Dakota
          Local Time:
          1:56 AM
          Would a smaller cam make it more street-able? If so how do you determine the cam size, I've often been confused about the real difference between say the OP's .573 and .590 and say .566 and .583 does it really make that much difference? seems like such a small change.
        • 1stgen
          1stgen Member
          14
          3
          Mar 24, 2019
          UK
          Local Time:
          7:56 AM
          Tyre size I’m running 295/50/15 and for fuel the best we have here in the UK is premium unleaded
        • fishmens67
          fishmens67 Well-Known Member
          7,381
          4635
          Nov 10, 2012
          idaho
          Local Time:
          1:56 AM
          Increasing camshaft lift has the effect as increasing duration, except doesn't change the opening and closing points on the lobe
        • MOPAROFFICIAL
          MOPAROFFICIAL Well-Known Member
          5,468
          4448
          Jun 1, 2016
          Beach
          Local Time:
          11:56 PM
          You're gonna have some decent cylinder pressure closing the intake valve @45 or earlier if they used the usual suspects when it comes to piston choice. If the heads are made to work right, it'll make some good torque. I would consider better exhaust valves when the dynamic is high on pump gas.
        • nm9stheham
          nm9stheham Well-Known Member
          12,002
          3854
          Dec 20, 2013
          Waynesboro, VA
          Local Time:
          2:56 AM
          Gas octane in the UK and Europe is Research Octane Number (RON), not the average of Research and Motor Octane Numbers that we use in the US, which gives us our lower-appearing octane numbers. 1stgen's octane of 95 is similar to 90-91 octane in the US, and if he can get 98 octane, that is similar to 93 octane in the US.
          Just running some numbers on the Dynamic CR, starting with a 10.9 static CR and making an educated guess on the advertised duration of the Hughes cam being around 298* (which is the .050" duration + 52 degrees) gives a DCR of 8.2-8.3..... With his AL heads, I think that is manageable, but needs proper attention to tuning. I have run iron heads, with quench, at 8.3 DCR on 93 US octane, but had to limit total timing some.
          Hopefully, he has set up the gasket selection and piston deck height to get some quench, which will help. Maybe he can share that info.
          • Agree Agree x 1
          • nm9stheham
            12,002
            3854
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            2:56 AM
            Hey MO. What would you consider to be 'better exhaust valves', and what is the particular reason to change them under these circumstances?
          • 1stgen
            1stgen Member
            14
            3
            Mar 24, 2019
            UK
            Local Time:
            7:56 AM
            Once again thanks for the reply’s, this is a big learning curve for me The pistons Hughes specified are icon forged -13cc dishes piston at zero deck with a fel pro race head gasket 4.180” x 0.39” also giving a cylinder pressure of 186psi
            Cheers Mark
          • dragfish
            79
            19
            Dec 13, 2006
            Local Time:
            1:56 AM
            I have no highway time yet have a 255 tire non drag radial on it and spins rather easily.I have 275's on my Cuda and 3.55's and 70 is no problem cruising.
          • MOPAROFFICIAL
            5,468
            4448
            Jun 1, 2016
            Beach
            Local Time:
            11:56 PM
            Get super alloy Ferrea valves on the exhaust side.
            • Like Like x 1
            • rumblefish360
              37,789
              9480
              Jun 21, 2005
              Local Time:
              2:56 AM
              Lift has a direct impact on HP. Not so much torque. The idea of lifting the valve high is to take advantage of the heads high flowing capabilities. If it has them.
              Duration is where the rpm band is determined and yes a smaller cam lowers the rpm band in which it operates in. You have to be careful because a small cam has the timing events closer together and this can cause cylinder pressure to sky rocket. Thus making pump gas impossible to run.
              Most cam manufacturers will list an operating rpm range where the cam should perform in. Crane goes as far as to even list the cruise rpm band in which there cam will perform in.
              Most other companies will list the cams power band range. Hughesengines has a listing in there tech pages on where a cam should be making power T a min and max if you follow there suggested parts to work with the cam being used.
              Without getting into cam talk, because it can get deep quick & be a little confusing, just follow the suggested parts list that the cam works with best. Cam manufacturers can play with the cams timing and ramps to come up with some pretty slick results. Unless you understand this kind of stuff, I suggest the K.I.S.S. Method.
              (That would be, Keep It Super Simple)
              Otherwise, you’ll end up on the phone with Comp or Crane or ..... talking about everything and then some more about the whole deal for the cam. They will want to know EVERYTHING about the whole deal. So be prepared to have every little detail about your car, trans, rear gear and tires & and wht you want to do or expect from it.
              If your well prepped and spend the time on the phone, chance is, your going to be REAL happy with the custom grind your going to get.
            • nm9stheham
              12,002
              3854
              Dec 20, 2013
              Waynesboro, VA
              Local Time:
              2:56 AM
              Comes out at 10.8 SCR so that part agrees with the earlier data.
              Is the 186 psi cranking pressure computed or measured?
              You do have a decent quench gap with that setup; that is good.
