Solid_Brass
Member
360 Magnum block is off at my machinist, hopefully get everything back at the end of the month. The end use for this engine is a street cruiser, not a track car. It will be going in my D200, but will eventually end up in my 70 duster. Rear end is Ford 8.8 with limited slip and 3.73 gears. Transmission is a 46Rh. I havn't decided on a torque converter yet. I'm not building for a specific HP number, just hoping in the mid 400's. It's getting a Scat 408 stroker rotating assembly (cast crank), Icon Forged -20.5cc dish pistons, and Scat I-beam rods. Heads will be Speedmaster 45cc (LA heads). Buying bare heads so I can have my machinist install new valve seats and guides, and I can port match exhaust in intake. Compression should be around 10 to 1 depending on if my machinist needed to deck the block any to square it. I wanted it to be 10 to 10.5 to 1 so I can use pump gas. It will be getting Holley Sniper 2 efi.
I'm trying to figure out what cam, rockers, lifters and intake to go with. I will need pushrod oiling so my lifters will need that feature, and thinking of 1.6 ratio. I would like to stay hydraulic roller. Intake I was thinking an Air Gap. For the cam, I would like the engine to have a little lobe to it, but something that will drive nicely if I take a weekend roadtrip to the coast. The only part of this engine build I already have is the block, and an MSD ignition system.
Nothing set in stone yet other than it's going to be a 408 stroker. I should hear back next week what it gets bored to so I can order the rotating assembly. As far as parts budget, 6k-ish. I don't really have a number i'm sticking to as I will buy/build as I can afford. I will be building the engine myself and this will be my first mopar engine. I am a Tool & Die machinist by day. I did buy the apropriate mopar engine books and have been reading them.
I apreciate any help and guidence
The rides:
The rides:
