408 Magnum HP Guesses
Yamridr38
Member
Killen AL
Any ideas on my new 408 HP?
5.9 Magnum .30 over
Edelbrock RPM 58cc aluminum heads
Edelbrock RPM air gap intake
Holley 700
4.00 Scat forged crank
forged scat rods
27cc forged Icon pistons around 10.1 compression
Comp xr286hr-10 236 242 @50 .580 lift
Comp 1.6 roller rockers
Hooker comp headers
1,000,000 horsepower
Hughes 408 kit
Cast crank
Forged rods
Hypereutectic mid compression (10.2 to 1 = 200 psi cranking compression)
Edelbrock Heads w Hughes Super Prep + additional port work
Hughes HER4652 108*, .555 In & .540Ex, 246* & 252* @.050
1.6 to 1 rockers
Airgap EFI
Hughes Big Gulp throttle body
Ford 4-hole 45 GPH injectors
TTI step headers w 3 inch full exhaust
Reflashed factory ECU from Chris @ Performance Injection Equipment
Measured on a chassis dyno through a 2004R & 3.91's & Converter has a 3800 stall.
Hughes 408 kit
Cast crank
Forged rods
1.6 to 1 rockers
Airgap EFI
That thing makes killer torque. Great wheel numbers.
The 2004R has a 2.76 to 1 first gear ratio. That with the 3.91's, the 3800 rpm stall converter, and being able to nearly dead hook on the street when the tires are warm has put more than a few people right in shock.
Nice. I really like your car a lot. I’ve followed it for a while on here now.
Good lookin numbers! Has the car been to the track at all?
No track time yet.
Its only been in the car a few days.
I'm only at about 100 miles as of today.
It sure will boil the BFGs though at the tap of the throttle though.
I'm thinking traction may be an issue.
BPC4085CTC
Complete Mopar 408 Stroker,
• HP & Torque: 465 HP / 494 FT LBS
• Compression Ratio: 10:1
• Aluminum Heads
• Roller Cam
• Cast Steel Crank
• Forged Pistons
BLOCK:
• Hand picked seasoned Magnum block
• Square and parallel decked
• Align honed main bearing bore
• Cylinders honed on computer controlled machine to within .0002 straightness and roundness
• Cylinders are sonic tested for thickness
• 2-Bolt Main
• 4.000" Bored .040" over
• 2-Piece Rear Main Seal
• Mech fuel pump provision: Yes
ROTATING ASSEMBLY:
• New Steel crankshaft
• 4.000" Stroke
• Forged Magnum 6.123" connecting rods w/ 150,000 psi bolts
• Forged pistons
• Externally balanced
CYLINDER HEADS:
• BluePrint Engines Assembled and Machined Edelbrock 61769 Casting
• Aluminum Magnum Pattern Cylinder Heads - 58cc chamber
• Aluminum Roller Rockers
• 2.02" intake/1.60" exhaust valves
• 176cc intake/75cc exhaust runners
CAM SPECS:
• Cam Type: Roller
• .580 Intake .577 Exhaust
• 235 Intake / 242 Exhaust duration
• @ .050 - 110 degree lobe separation
IGNITION TIMING:
• 34 degrees total at 4000 RPM
Whats the build info on your motor?
BPC4085CTC
• Aluminum Heads
• Roller Cam
• Cast Steel Crank
• Forged Pistons
BLOCK:
• 2-Bolt Main
ROTATING ASSEMBLY:
• 4.000" Stroke
• Forged pistons
CYLINDER HEADS:
CAM SPECS:
• Cam Type: Roller
IGNITION TIMING:
Thanks, sounds like its about the same build as mine.
No track time yet.
No headers on that motor? Do you have any plans on seeing what it will put out on a chassis dyno?
I found regular street radials to dangerous to drive on, and switched over to Nitto Drag radials. It helped a lot with traction issues. They work just as well in the rain as the BFG's too.
There will probably be some TTI shorties and x-pipe exhaust coming in the future.
I need some time to recover financially from the new motor and trans.
I'll probably just use my butt dyno for the foreseeable future.
I'm still taking it kinda easy as I am only "about?" 200 miles (broken speedo and odometer) as of tonight of my 500 break-in period.
