Roadhunter
Active Member
I have an annoying engine vibration in my 408 stroker and am looking for suggestions. This has an internally balanced Scat forged rotating assembly which was installed by the builder(not me) and was sent out again to a different shop and rebalanced. The notes he made was that it still had the vibration "can I live with it?". I asked him about it and if i should try a new fluid balance and he said everything was balanced together. It is annoying to be driving at cruising speed and get that rhythmic vibration through the steering wheel. Is the a risk of doing some major damage if I keep running it this way? I have put less than 50 miles on it since I have owned it and has less than 800 from being rebuilt.
Thanks
Thanks
