[SOLD] 408 Stroker kit and Magnum Top end.
93dakman!
carmi
Rating - 0%
0   0   0
I am selling this because I want to build a forged solid lifter high rpm engine for my pulling tractor. I bought all of it to build a nasty 408 for my durango but never got around to it.
I am asking $1600 for all of whats listed below. I am in Crossville, Il 62827.
Lunati Roller cam with 219/227 @.050
Magnum Roller Rockers
Magnum Pushrods
Mopar stroker pistons (p5007478) for a standard bore 360 and 4" stroke.
Piston ring set
Scat 4" stroker crank for 360 mains
Magnum rods
Rod Bearing Set
Crank Bearing Set
Assembled Magnum Heads with 1.6 rockers
Head Bolts
Magnum Valve Covers
Exhaust Manifolds
Magnum Intake Manifold with:
Complete fuel injection system, fuel injectors, fuel rail, injector wiring harness
Throttle body with all sensors
Complete engine wiring harness.
I forgot to add that also with this comes the Mopar magnum distributor and the factory cmputor ecu
Sent you a Pm I dont need any of the new stuff will you seperate
UOTE=93dakman!;1970087531]I am selling this because I want to build a forged solid lifter high rpm engine for my pulling tractor. I bought all of it to build a nasty 408 for my durango but never got around to it.
Magnum Pushrods
Piston ring set
Magnum rods
Rod Bearing Set
Crank Bearing Set
Head Bolts
Magnum Valve Covers
Exhaust Manifolds
Complete engine wiring harness.[/QUOTE]
Hey 93 dakman. I have a 93 magnum 360 that I am overhauling to put in my 92 4x4 Dakota. I was wondering if you had some advise on combinations of parts and I was pretty interested by the deal you have here. Would this be compatable with my engine?
Is this still available and if so are there any pics of these parts. Also can you give a part number for the cam so I can look for more information on this. Thanks
Rodney
