408 Stroker
Discussion in 'Small Block Mopar Engine' started by wgarland65, Aug 14, 2018.
  1. wgarland65
    wgarland65 New Member
    3
    0
    Aug 14, 2018
    Ohio
    Local Time:
    3:42 PM
    Hi, New to the forum and have a few tech questions. I ended up getting a Wrangler barn find for $400 came with a 78 360 .030 over and a bunch of new parts. New pistons Speed Pro H405P flat top 4 relief cuts. I'm researching builds and wanting to get the best performance I can without tons of money. Here are my plans if they work the new pistons are on stock rods, 4" stroker crank, 96 5.9 heads and Hughes 360 whiplash cam. The only thing not written in stone is the crank. The new pistons have a compression height of 1.637in and I research the stroker pistons the compression height is 1.459in. There is .178in more piston on my set. Would having the 4" stroker crank create a drastic issue with valves and head clearances. Any advice is greatly appreciated.
  2. 12many
    12many Well-Known Member
    547
    676
    Dec 14, 2016
    South Carolina
    Local Time:
    3:42 PM
    Just wondering, why is that cam choice in stone?
  3. wgarland65
    3
    0
    Aug 14, 2018
    Ohio
    Local Time:
    3:42 PM
    I've been looking all over the web other mopar sites and like the idle and torque curve this has from tube videos.
  4. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    2,696
    1732
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    3:42 PM
    Just a thought? Maybe go this route? My 408 stroker. Lol
  5. rklein383
    rklein383 Well-Known Member
    1,312
    184
    Dec 2, 2005
    View My Photos
    Local Time:
    2:42 PM
    My 408! I would help you, but the machine shop purchased my crank, Eagle rods, and KB pistons. I am not sure even what the specs were. Rod
  6. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    2,780
    1752
    Jun 1, 2016
    breakwater
    Local Time:
    12:42 PM
    Cam sucks.
    • Agree Agree x 1
    • MOPAROFFICIAL
      2,780
      1752
      Jun 1, 2016
      breakwater
      Local Time:
      12:42 PM
      Those pistons would be sticking out of the block... but if heads could hold them the cylinder pressure with that wimptrash cam would have it grenading on pump gas
      Get the right pistons for the stroke.
      • Agree Agree x 1
      • replicaracer43
        replicaracer43 Old school member
        3,731
        2150
        Oct 10, 2008
        View My Photos
        Local Time:
        2:42 PM
        Stock pistons are not gonna work with a 4" crank
        • Agree Agree x 2
        • wgarland65
          3
          0
          Aug 14, 2018
          Ohio
          Local Time:
          3:42 PM
          Thanks guys, I've got the stock crank. What would be a good cam recommendation it's going in a Jeep Wrangler with 5 speed. I don't need a ton of horsepower but it would be fun. I guess I didn't get lucky enough to get a stroker in all the parts I got. Just wasn't sure .178 was going to create that much of a change. Great looking motors.
        • Wyrmrider
          Wyrmrider Well-Known Member
          877
          277
          Sep 5, 2016
          los angeles
          Local Time:
          12:42 PM
          dont think about a cam till you get your pistons and compression ratio worked out
          what kind of jeep use, what gears, tires
          lots of difference with a rock crawler application and a off road racer or snow plow
          do you have a 4" stroke crank
          the piston stock crank combination will give you a very low compression ratio
          Speedpro h116cp or kb107 are the pistons that will get ya there..
          Speedpro H405 pistons, what to expect for performance?
          do some research
          which heads- casting number please
          do the math- get the results you MUST learn how to calculate deck height/clearance, compression ratio, etc
          • Agree Agree x 1
          • 1994redram
            1994redram FABO Gold Member FABO Gold Member
            963
            454
            May 9, 2012
            Oklahoma
            Local Time:
            2:42 PM
            Why build a stroker? I owned a jeep for awhile and had a complete good know magnum to swap in. Realized i didnt want to upgrade the whole drivetrain. So i left it alone and got rid of the magnum.
            The stock 5 speed will likely grenade, then the axles, driveshafts, the transfer case is probably a bit too weak also. Why don't you just build the 360 and use the new pistons you already have. Throw some magnum heads on it if you desire. Or find some X or J heads and have them cleaned up and put a mild cam in it. It'll be very cheap since you have most of it from the sounds of it. And if you truly need more power you can always build a 408 while you are driving the jeep around with a 360.
            • Agree Agree x 1
            • Fisher
              Fisher Old Guy with a Cool car.
              1,716
              611
              Jul 22, 2012
              Regina Sask Canada
              Local Time:
              2:42 PM
              What headers are those?
            • Wyrmrider
              877
              277
              Sep 5, 2016
              los angeles
              Local Time:
              12:42 PM
              good question
              I usually did the center two over the outside two and the intersection of the outside two looks questionable
