A couple of weeks ago, I drove my car from work to home and when I got to the hill my house is on, the car randomly shut off. After that, the car would crank a bit, but wouldn't turn over. I put 2 gallons of gas in the tank and it would fire up but die immediately. After that, it would just sound like the starter is turning, but nothing was happening.
I finally got around to work on it today. Good news and bad news. Good news, took the old starter to Autozone and it tested out good. Bad news, I don't know what's wrong. I reinstalled everything and tried starting the car up again. With a couple of pumps of the gas pedal, it will start and shut down when the ignition is turned. Without any pumps of the gas pedal, it sounds like the starter and flywheel just free wheel. When I keep my foot on the gas and turn the key, it will start up, but I have to keep my foot 1/2-3/4 throttle in order to keep it running and it does not sound happy. Idk what's wrong, but now it's starting to sound like a fuel problem. I have new spark plugs, since all of the old ones were black, but I'm not sure if I want to install them just yet to check to ensure it is fuel. Video attached of me trying to start the car a couple of times. I honestly have no idea where to start with this?
Now here's the thing, I have a brand new Holley Sniper, Tanks Inc EFI tank, Stealth Aermotive Fuel Pump, new lines, new fuel filter, etc. all waiting for the swap. Should I bother trying to make this thing run or should I just start the swap?
