slapstickjim
Looking for your thoughts.
I bought a dart sport in January and been addressing a small list of things to tweek. The holley 4160 sits on top a mild rebuilt 318 and runs great. I honestly have not seen or worked on a carb in forever, so I'm rusty.
Over the weekend I had the dart out a few times and was smelling gas in garage after I parked it. Then on. Monday I went to back it out and it had trouble running and starting. My thought was seems like it's flooding. I took aircleaner off and with it running,, gas was dripping in secondaries. More like a super strong drip almost a stream. When I shut engine off it kept dripping and started running out of carb at butterfly thingies. Read up and suggested bad or dirty needle or float to high.
Being I have not touched a carb in 25 years, I'll give run down what I tried. I took the screw and 5/8 nut off attempting to remove needle and seat. That did not remove needle. So With nut and screw off I blew in there thinking to release dirt. Reassembled started car and adjusted rear float, so gas came out when I would rock car a lil. While at it I adjusted front float also. And took for ride and back home that gas drip cleared up. So far cost me nuthing.to do this.
Questions.
1. Was that the problem?
2. Did my fix fix it or should I removed rear bowl to get dirt cleaned up?
2 other things with carb questions but this issue first
Thanks for your input
Jim
Questions.
Jim
