mario03srt
All,
During my engine install I got around to installing my 90 degree oil filter adaptor. Turns out the Bolt and Washer Kit from Brewers is way to tall for the 4719425 Alum Housing I bought from here. In searching the p/n it turns out that I found some matches which said it was a 318 only. To make it work I need a completely different through bolt. Also I see that there are cast iron adapters with a taller "hat" that appear to fit the bolt and gasket kit that I bought.
Will this work on a LA 360 w/ headersand if so where can I source a bolt? Or is it 318 unique?
Thanks,
Marion
Thanks,
Marion
