moparraceman
what parts does it take to get a 422 small block ? block bore crank rods and etc thanks
The ones that have 8 wet sleeves installed!How many 360's you known go .100 overbore!!!!??????
LMAO!!!
Wet sleeves (don't think they make them) aka bore would have to be bored into the coolant passage to get a .100 over bore sleeve to fit in stock block. Then would need some kind of o-ring seal to keep the coolant out of the crank.
That's what it would take but was mostly being a "smart ***". Anything can be done but the cost could not justify the act.
However i have a .060" 340 block that is waiting for that dream.
Ok you can get piston for up to a 4.100. with a 4.18 stroke...... 99 percent of them will be a week flexie cyl wall.Click here, 4.18 stroke cranks.
Hughes Engines
And you KNOW this how?Ok you can get piston for up to a 4.100. with a 4.18 stroke...... 99 percent of them will be a week flexie cyl wall.
Hence theI'm having trouble figuring out what the heck your talking about since I'm talking about taking a stock 360 block out .100 and your telling me that your not even sure they make thenparts to fit an engine that needs to have the entire cylinder taken out to fit in a sleeve just so you can go 4.100.
Seriously! Not even cost effective if you were rich. Come on now bro! REALLY!!!!!!
My core shifted 340 block(4.100 aka .060 over bore) had a crack down the cyl wall the was vary vary thin!And you KNOW this how?
LMAO!!!
True that! wouldn't it be cool to win the lottery and have someone build you a kick *** Mopar stroked small block. Something similar to the supercharged Hellcat motor in that it would have all the best tech and the BEST of everything, but all classic small block Mopar. If the motor cost $40,000, who cares. You won the lottery. With a million dollar budget, I could have the BADDEST 69 fastback on the planet. Hmm, I think I'll go buy a lottery ticket.Anything can be done but the cost could not justify the act.
GROAN!!!!!!!
So we're back at square one ... again ...
@Cudafever .... ? 2 U
Max overbore on 340's, 360's?
Whatcha got?
I understood that the early 71 360s were 340 castings with oversized mains and underbored.... I used 1 for a w2 stock strock engine in the early 80s and the shop said walls showed lots left after .060 over bore...
Is that just folklore ?
