426 hemi in a 66 dart??????
Big Block A body Tech
  1. johnmucci
    johnmucci moparmucci
    622
    38
    Dec 16, 2008
    Davenport Florida
    Local Time:
    5:00 AM
    OK Besides a wallet full of cash, what would i need to put a 426 hemi in a 66 dart gt that is now a 6cyl..?????? the motor of course ...ha ha...I am talking frt end issues, kframe, etc... please chime in... thanks!!!
  2. 66dartman
    66dartman Well-Known Member
    1,165
    6
    Apr 25, 2005
    Littleton, CO
    Local Time:
    3:00 AM
    AlterKtion for starters.
  3. altered A-body
    altered A-body Banned
    120
    0
    Feb 4, 2011
    Colorado
    Local Time:
    3:00 AM
    Alterkation will defintly make it easier. Then you'll need:
    Custom Headers
    Big Block Tranny
    Bigger Rearend
    Bigger Radiator
    Probably some inner fender Tweaking
    Custom Driveshaft
    Torque Converter
    I'm missing a bunch, but that will give you a reason to start saving money and working overtime.
    You should call Bill at Reilly Motorsports and talk w/ him about his front end.
  4. 1968FormulaS340
    1968FormulaS340 Well-Known Member
    11,541
    474
    Aug 24, 2005
    St. Helens Oregon
    Local Time:
    2:00 AM
    $50,000 should get the job done. I think that's more than a wallet full.
  5. pettybludart
    pettybludart Well-Known Member
    15,687
    122
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    4:00 AM
    Why not just builder a killer stroker and have Hemi HP out of a small block,without breaking the bank.:D
  6. Blownfish
    Blownfish Well-Known Member
    1,084
    7
    May 26, 2009
    St.Louis
    Local Time:
    4:00 AM
    That's an understatement, It's going to need A LOT of tweaking. I barely have room for my smallblock.
  7. bOb shingler
    bOb shingler Well-Known Member
    3,250
    159
    Jun 8, 2007
    warrenton, north carolina
    Local Time:
    5:00 AM
    first thing you might want to do is measure the 426 at it's widest point. second measure across the engine bay between the shock towers. if i recall correctly the 66 and older "A"s are 2" narrower then the 67 up ones and the 426 was REAL tight in those.
  8. 340eh
    340eh Driver
    52
    0
    Apr 1, 2005
    Canada
    Local Time:
    10:00 AM
    I'm thinking 3G 426 Hemi would be easier if not exactly cheaper.
  9. moper
    moper FABO Gold Member FABO Gold Member
    15,709
    1849
    Dec 27, 2004
    eastern CT
    Local Time:
    10:00 AM
    Basically, take the fenders and hood off, cut off the front frames at the fire wall, and reconstruct out of square tubing, using a rack and pinion and struts. Then re-mount the fenders. You'll still need a hood.
  10. Blownfish
    1,084
    7
    May 26, 2009
    St.Louis
    Local Time:
    4:00 AM
    Don't even bother measuring it, it physically won't fit between the original fenderwells, it will need major modifications.
    Here is my smallblock to show you how tight it is, and I do have to lift the engine to remove the header, my blower belt is also within 3/4" of the radiator.
    [​IMG]
  11. 74Dusted
    74Dusted Stock Piler of 340's
    1,699
    316
    Apr 11, 2011
    Lewistown, PA
    Local Time:
    5:00 AM
    Fixed your description for you :D lol
  12. 604B1duster
    604B1duster Well-Known Member
    1,252
    466
    Dec 30, 2007
    Local Time:
    3:00 AM
  13. 604B1duster
    1,252
    466
    Dec 30, 2007
    Local Time:
    3:00 AM
  14. hemichuck
    hemichuck Well-Known Member
    928
    91
    Jan 12, 2012
    Louisville Kentucky
    Local Time:
    5:00 AM
    Actually the years are 67 and older or 68 and newer,I found out while building a Hemi Dart about 19 years ago that the 1967 shock towers had to be moved back to accomodate a Hemi. The 68 and later are a smidge wider. You still cant get your hand between the valve cover and the fenderwell on 68 and ups. I still have an offset brake block if you need one to move that master cylinder.
  15. inkjunkie
    inkjunkie Well-Known Member
    17,132
    2401
    May 24, 2009
    Local Time:
    2:00 AM
  16. Purple Haze
    Purple Haze Well-Known Member
    2,216
    26
    Apr 5, 2010
    AridZona
    Local Time:
    2:00 AM
    From reading most of the post I would say full frame car.
  17. pettybludart
    15,687
    122
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    4:00 AM
    Now why,d you have to go and post this link.LOL.It would be nice to have a Hemi for my 66 Dart race car,but isn,t in the cards nor my pay check.:wack:Would be cool just for the WoW factor if I had unlimited cash flow.:burnout:
  18. HemiDenny
    HemiDenny HDK Suspension FABO Gold Member
    7,864
    1294
    May 31, 2006
    NW Ohio
    Local Time:
    4:00 AM
    I put a few Hemis in the 67 and up A bodies (no AlterKation, but my own custom K-frame)......everything under a stock flat hood,column shift automatics,4 and 5 speeds, A/C.....all without any sheetmetal modifications....and it's tight.
    the older ones ....66 and older...being a bit narrower....be prepared to do some surgury....and ruin any resemblence of a stock install.
    but as they say...if you got enough money...you could put a helicopter motor in a submarine
  19. Blownfish
    1,084
    7
    May 26, 2009
    St.Louis
    Local Time:
    4:00 AM
    No, 67 and newer are the same, 66 and older are almost 3" narrower
    I agree, I seen how much work a local guy did to his 69 Cuda to make a 426 fit, and the 65 is about 3" narrower than the 69
  20. 6pakattack
    6pakattack Well-Known Member
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    4:00 AM
    Just go with the 426 cu in SMALL BLOCK !!!Or hell,440 six pack small block !!!:cheers::cheers::cheers::cheers:
  21. moper
    15,709
    1849
    Dec 27, 2004
    eastern CT
    Local Time:
    10:00 AM
    There's no way I'd want the stock suspension or brakes with that thing over the wheels. Cut it off, make a new one...
  22. 65Vart
    65Vart Well-Known Member
    3,147
    30
    Feb 13, 2009
    Waterdown, Ontario
    Local Time:
    5:00 AM
    Pretty sure Ive seen a member's car(Valiant) here with an old school 392 Hemi in it, red car.
  23. 604B1duster
    1,252
    466
    Dec 30, 2007
    Local Time:
    3:00 AM
    Blownfish, first let me say I love your car ! I built a 65 440 Bcuda with fenderwell headers. Had to tip out the right shocktower a bit. It worked out well. The petty car was all cut up, firewall moved back etc. The link I posted is about a replica of the Petty car. It was built on a budget and no major surgery was done to it except the pass fenderwell/ shock tower. Take a minute to read it. I asked about a hemi in an early A maybe a year ago and someone posted that link. When I start squeezing it in I will post some pics.
  24. Craven Moorhead
    Craven Moorhead Well-Known Member
    183
    0
    Jun 9, 2010
    Wisconsin
    Local Time:
    4:00 AM
    I have a 440 in my 65 no cutting of the inner fender wells, stock front end.
  25. Blownfish
    1,084
    7
    May 26, 2009
    St.Louis
    Local Time:
    4:00 AM
    The problem is you can't just cut the one fenderwell and offset the engine that far to the right of the car, it will need to be more centered up than that, the original engine is offset, but the Hemi is just too heavy to be offset that far, you'll end up with steering problems and suspension problems.
    I know the one in the link is a clone, and it looks very butchered up under the hood, he also spaced the k-frame from the frame rails to give more space under the hood and over the steering box.
    I just think if you are basing your transplant on that car, you'll end up with a lot of headaches and a butchered car when your done. I'm not saying it can't be done, but to do it correctly, you are going to be doing a lot more work that you are anticipating, and I don't see the point in taking short cuts that will come back to haunt you later in the build.
