440 A body headers
Big Block A body Tech
  1. Alex linares
    Alex linares Member
    12
    9
    Aug 9, 2020
    Martinez ca 94552
    Local Time:
    3:34 AM
    I really didnt want to cut out the inner fenderwells so i did some research for a Stock high performance 440 and landed on these TTYs from schumaker, easy install with plenty of clearance, they do have smaller tubes which eliminates them from a race header, but they have excellent midrange power for a street car, and has much better flow than stock HP manifolds.
    • Like Like x 2
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
      3,041
      2381
      Jan 1, 2018
      Southwest VA
      Local Time:
      6:34 AM
      That looks better than most cheap small block headers. What size and length of tubes? On a mild street build, if they're 1-5/8 tubes I doubt you would have any noticeable gains from switching to a 1-3/4 or 1-7/8 inch primary tube with a full exhaust system in place.
    • SLOPAR72
      SLOPAR72 Well-Known Member
      2,285
      1676
      Jan 5, 2016
      Richmond, VA.
      Local Time:
      6:34 AM
      Probably the number one hurdle for the B/RB is the Exhaust situation. You won't go wrong with the Schumacher headers but it leaves some power on the table. I am only guessing that if TTI or anyone else could make something different to accommodate Powersteering, easier plug access, and a full tube design they would. Unless you have a specific need for the bigger power you will be fine with the Tri-y's.
      JW
      • Like Like x 2
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        16,999
        5193
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        5:34 AM
        Is Schumacher back in business? They are nice headers. Kim
        • Agree Agree x 1
        • Alex linares
          Alex linares Member
          12
          9
          Aug 9, 2020
          Martinez ca 94552
          Local Time:
          3:34 AM
          Yes, the problem is until they have enough orders of that specific header you will be waiting awhile, usually months.
          • Thanks! Thanks! x 1
          • thesiren74
            thesiren74 Well-Known Member
            1,368
            965
            Feb 23, 2014
            kenosha,wi
            Local Time:
            5:34 AM
            I them too and they are so much nicer than big tube headers, so much room.
            • Like Like x 1
            • 318willrun
              318willrun Utube channel 318willrun
              15,690
              16927
              Sep 13, 2013
              I'm here
              Local Time:
              5:34 AM
              Nice!~ What they going for $$$ these days?
              • Agree Agree x 1
              • Alex linares
                Alex linares Member
                12
                9
                Aug 9, 2020
                Martinez ca 94552
                Local Time:
                3:34 AM
                Thats the bad news, depending on the type of coating, dam near 1k by the time they are delivered, keep in mind these are thick quality pipes and for a little extra you can get the swivel extensions that bolt to collector, i can show pic if anyone requests.
              • oldkimmer
                16,999
                5193
                Nov 11, 2006
                Local Time:
                5:34 AM
                Pics would be nice. How long ago did u get your headers? Kim
              • Dartvader440gt
                Dartvader440gt Well-Known Member
                90
                86
                Jul 17, 2013
                Tiverton
                Local Time:
                6:34 AM
                I believe these are the headers I got for my Dart many years ago (maybe 10?). I remember having to put a few dings with a sledge. Needed some extra clearance. They do work nicely with power steering. They were ceramic coated then and seem to still be holding up well.
