440 B body manifold clearance
Discussion in 'Big Block A body Tech' started by Markbo, Mar 13, 2018.
  1. Markbo
    Markbo Well-Known Member
    59
    21
    Feb 15, 2017
    So Cal
    View My Photos
    Local Time:
    6:53 AM
    So a prev owner shoehorned this 440 into a 72 dart. The coupler is kissing the exhaust manifold. (Probably why steering box is loose and the column shaft is being pushed a bit toward the fenderwell)
    Any options short of headers or swapping out the Power steering box?
    Thank you all.
  2. Jim Lusk
    Jim Lusk Well-Known Member
    3,775
    266
    Mar 8, 2006
    Fresno, CA
    View My Photos
    Local Time:
    6:53 AM
    Angle mill the manifold, but those don't look like the HP manifolds which would be a better choice.
    • Like Like x 1
    • mzak88
      mzak88 Well-Known Member
      129
      78
      May 22, 2014
      Kelowna ,BC,Canada
      Local Time:
      6:53 AM
      Check the left/right orientation at crank centerline in relation to frame section of unit body. 1" offset to pass side is acceptable. I would start there
    • RustyRatRod
      RustyRatRod Just another dumbass. FABO Gold Member Technical Editor
      45,695
      9704
      Jun 7, 2010
      Georgia
      View My Photos
      Local Time:
      9:53 AM
      What "I" would try first would be the easiest. Loosen the bolts that hold the column seal adapter to the firewall and try prying the whole thing over to the driver's side and re-tighten. I've had success with that in the past. It doesn't look like you need much room.
    • Markbo
      59
      21
      Feb 15, 2017
      So Cal
      View My Photos
      Local Time:
      6:53 AM
      Thanks Jim!
    • Markbo
      59
      21
      Feb 15, 2017
      So Cal
      View My Photos
      Local Time:
      6:53 AM
      I’ll check, but pretty tight over there too. Thanks
    • Markbo
      59
      21
      Feb 15, 2017
      So Cal
      View My Photos
      Local Time:
      6:53 AM
      Good idea. Worth a shot. Thanks!
    • famous bob
      famous bob mopar misfit
      9,580
      2055
      Aug 14, 2011
      okla
      Local Time:
      8:53 AM
      THIS WILL HELP! Youcould also turn down the coupler a few .000 , and slightly grind the rust off the manifold too. All 3 will probably do it !
      • Like Like x 1
      • mzak88
        129
        78
        May 22, 2014
        Kelowna ,BC,Canada
        Local Time:
        6:53 AM
        I would just be wanting to know how P.O. set the big block up in there. When I did the 440 in mine, many moons ago, it was Uber tight to pass side. To the point of grinding fins off exhaust manifold. That was with a 1” offset.
        • Like Like x 1
        • Markbo
          59
          21
          Feb 15, 2017
          So Cal
          View My Photos
          Local Time:
          6:53 AM
          Passenger side inner fender has been shaved back..
