[FOR SALE] 440 built engine complete
Charlie...can't have your phone number on the ad. Can you tell us a bit more about the actual specs? Stock? Over bore? Cam specs? The more info you provide the better your chances. Good luck with sale!
the engine is totally built, .030 overbore,cast pistons, has 6 pac rods, crank has been turned .10-.10, rods have been reconditioned, 9:1 compression ratio, clevite bearings, fel-pro gaskets, stock volumn oil pump, 5 angle valve job, brass freeze plugs, reconditioned rocker arms.
Makes 455 horsepower on pump gas, ready to run
note: since I am a gold member, I can put my phone number in my ad
mopar charlie
