fratzog lover
Lost my wifi. Sorry for multiple posts
It's kind of hard to take cost out of the equation. Does the price for FI include the tank? Plug and play complete? Seems to be more than $1k for a complete FI setup. Carb can be had for $400+
I would use FI over carb but until the price difference becomes close, I'll stick with the carb.
All depends what you're trying to do. A good race carb is at least $1000 or more and a data logger is another $500 or more. A computer controlled ignition setup can run another $500 to $1000. So if you're going to buy a race carb, computer controlled ignition and a data logger you might as well buy a Sniper kit since it will be less expensive.
If all you want is a $400 carb then buy a $400 carb. But don't compare that to a EFI system which has a lot more bells and whistles than a $400 carb.
The original question was carb or FI. Not carb with data logger and computer controled ignition or FI. If anything extra it would be an a/f meter to tune. There is still a large cost discrepancy. I'm curious if the dedicated drag racers are moving away from dominators to fuel injection.
If you're building a classic Mopar muscle car, buy a carb. If you're building a wanna be BMW, then go EFI.
The Holley Sniper is $999 and it comes out of the box with data logger and the ability to control the ignition. It also has the ability to run a digital dash setup, control electric fans, etc. All of that stuff is built in. If you buy a carb and then add all of that stuff you'll end up spending 3x as much money.
And you still need an efi fuel tank for it, fuel pump and distributor. The $999 kits don't have that included.
I run a stock tank, w/ dual pick ups in the rear lower corners. Pump mounted like dart 273 said. The 3/8" new stock type feed line is used for my return, w/ the sock cut off, left as long as possible to prevent aeration. . You cant hear the pump when the engine is running. It is situated so the dual filters gravity feed the pump. The pump came w/ my f.inj system.
When I bought the new tank, I HAD A PRO WELDER WELD TWO OCTAGON SHAPED,1/2" PIPE CAPS ON THE REAR LOWER CORNERS OF THE TANK, THAT I HAD DRILLED THE end CAP PART OUT TO THE THREAD SIZE. After ward I took a long tapered punch and drove it thru the cap, penetrating the tank until the hole was as big as the threads of the cap. I wish I had put them in a little lower tho, maybe even in the very bottom of the back corners. Obviously a person would have to take great precautions w/ a used tank , to avoid an explosion! The tank is tapered up in the rear so it shouldn`t be a problem w/ them in the very bottomDo you have pics of your setup? Is it made specifically for the stock tank? That would be a nice alternative to buying another, more expensive tank.
FI requires a computer to function. When the computer craps out how does one limp the car home or at least to safety? I'm a "worse case scenario" type of guy.
Not much different than if your chrome box stops working. Or your ballast resistor, or coil, or ignition pickup, or alternator, etc. New cars seem to be a lot more reliable than anything the factory built in the 60's or 70's so I don't see a problem with using the new stuff on older cars. Seems like an upgrade to me.
Well thanks much for all of the feedback and ideas. Since my Edelbrock 1412 is working well I am going to stay with it for now. Clearly there are benefits with FI but not enough to swing me over based on how I use the car. $999 vs $700 for the 1412 plus a fuel pressure regulator with associated AN fittings and braided lines, insulated base plate, manual choke cable, 1480 calibration kit, etc. isn't that big of a difference.
