440 heads whats better??
Big Block A body Tech
  1. MoparMower
    MoparMower Well-Known Member
    71
    3
    Apr 3, 2015
    Oak Harbor, Washington
    Local Time:
    2:48 PM
    Im going for a nasty street strip car on a $3'000 budget.. the base is a 440 duster iv affectionately ned the "mopar mower" ....... even though the only thing its mowing down now is the parking spot it sits in! :D lol
    So heres the question..
    Iv got a set of 906 heads in damn good condition right now, but need to make a decision on wether or not i should get those mechined with a lil port n polish, maybe a good valve job and some hardened seats. OR drop $800 on set of Edlebrock proformer RPMs an slap them puppies on there to add some bark!
    Anddddddd go!
  2. crackedback
    crackedback FABO Gold Member FABO Gold Member
    18,779
    3099
    Aug 7, 2005
    92201
    Local Time:
    2:48 PM
    800 on a set of ede's????
    They are 800 each!
    Best, easy to bolt on head coming out is going to be the trick flow cnc pieces.
  3. MoparMower
    71
    3
    Apr 3, 2015
    Local Time:
    2:48 PM
    Thats not the price for a set????
    Ohhhhh lawd....
  4. hangn0ut
    hangn0ut Well-Known Member
    747
    120
    Dec 3, 2012
    rialto.ca.
    Local Time:
    2:48 PM
    Yeah,ya might want to rethink that plan. Bang for the buck? Think nitrous....
  5. MoparMower
    71
    3
    Apr 3, 2015
    Local Time:
    2:48 PM
    i like where your going with this nitrous idea.. but id probably end up blowing up my engine with that one and be back to square one. But who knows, maybe one day!!!
    what about an average cost for mechining my 906 heads? Could i fot that in the budget?.. not a lot of experiance with these things.
  6. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
    31,576
    10469
    May 21, 2011
    Arroyo grande ca
    Local Time:
    2:48 PM
    Nitrous ( 125-150 shot), is cheap,easy,& addictive. I would pay attention to fuel line size (1/2"- AN -8 size), fuel pump quality ( a high quality Edelbrock/ Carter mechanical pump, a GOOD electric pump, Holley blue/Carter HP 4601 electric...), and at least a good stock electronic ignition . MSD/Holley digital box,even better. Every fifty ponies of spray, minimum 2 degrees retard total timing,@2500-3000. As for budget heads, check out Edelbrocks EZ heads line,& 440 Source's Stealth heads.
  7. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    56,058
    21519
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    4:48 PM
    Max Wedge....
  8. Abodybomber
    31,576
    10469
    May 21, 2011
    Arroyo grande ca
    Local Time:
    2:48 PM
    Karl, those are tasty. Lucky enough to get a few rides, in a pair of well prepped rides with these. Before they became aftermarket available, it was a rare treat.
  9. the67fish
    the67fish Well-Known Member
    1,080
    16
    Sep 14, 2009
    Fort Worth Texas
    Local Time:
    4:48 PM
    My bracket car had 906s with manley high flow valves, no port work and a rocker stand on one broke in the middle of a points season, needed heads quick so I got a set of the very first batch of the RPMs made. I changed valve springs, put em on and had to make new push rods, otherwise....it ran faster with the 906s LOL, thats tells you they wanted more cam than I was running at the time. Im gonna fix those 906s some day.
  10. winstoninwisc
    winstoninwisc Taint easy livin free,season ticket ona 1wayride
    2,333
    112
    Aug 1, 2012
    sun prairie wi.
    Local Time:
    4:48 PM
    E_Z"s are just what the doctor ordered ,you get the best of all worlds there
    • Like Like x 1
    • 69 Cuda 440
      69 Cuda 440 Legandary Member Legendary Member
      4,248
      228
      Dec 12, 2012
      Wilton, Connecticut
      Local Time:
      5:48 PM
      Edelbrock #60189 Cylinder Heads
      An excellent product, but they are $775 'EACH' for a complete 'HEAD'.
      If you're on a budget, that's a tough 'wall' to break.
    • 1qwikScamp
      1qwikScamp Well-Known Member
      763
      5
      Aug 22, 2006
      soddy daisy TN
      Local Time:
      4:48 PM
      3k on the whole car? I wouldn't spend the money to have the 906s worked I would invest in a good cam intake and carb to run with what you have going.
    • moper
      moper FABO Gold Member FABO Gold Member
      15,771
      1887
      Dec 27, 2004
      eastern CT
      Local Time:
      10:48 PM
      If you want something cheap for the street, have the 906s done by a competent shop with good equipment. Have everything done - new guides, spring seats cut, etc. Have them put a back cut on the intake valves with a 5 angle cutter-type valve job. That work will get you the same or more than quick hand cleanup. Then bolt them on with a cam that's small enough to keep the valves out of the pistons. Safe your etra money for a decent convertor and/or some gears. Then run it. That should give you close to an honest 1hp/inch with some great torque. Enough to run low 12s or quicker with good matched driveline parts in an A body. The engien is only a part of making a car fast. If you only have $3K, only about half can be spent on the engine, with the rest on the stuff to support it.
    • roccodart440
      roccodart440 Well-Known Member
      5,685
      4686
      Apr 19, 2010
      Local Time:
      5:48 PM
    • 451Cuda
      451Cuda Well-Known Member
      1,911
      697
      Nov 19, 2008
      Port-aux-Fran├žais, TF
      Local Time:
      4:48 PM
      With only a $3k budget I'd just do a clean up on the 906's and focus on building a solid bottom end. Then save your pennies and get a set of the new Trick Flows to replace the 906.
    • bOb shingler
      bOb shingler Well-Known Member
      3,250
      163
      Jun 8, 2007
      warrenton, north carolina
      Local Time:
      5:48 PM
      X2 on 451cuda. balance the motor with lite pistons, a good chain, oil pump, deep pan and rods.
    • MoparMower
      71
      3
      Apr 3, 2015
      Local Time:
      2:48 PM
      Lol there seems to be a missconseption here.
      I should have clairified earlier i reckon but it aint like 3000 is all im gona spend on the car period. Thats just how much i have saved up at the moment to kick off the build.. Ill have plenty more i just gota save it up over a few pay checks. Im really liking the idea of just redoing the 906s though! And iv already got a good intake manifold, my carb is a holley 1406 double pumper but its all out of wack and needs a rebuild as well.
      Tranny is a 727 with reverse manual valve body and i have the 8.75 rear on it already.
    • MoparMower
      71
      3
      Apr 3, 2015
      Local Time:
      2:48 PM
      Not sure what gears are in it though.
    • 451Cuda
      1,911
      697
      Nov 19, 2008
      Local Time:
      4:48 PM
      1406 is an Edelbrock number, are you sure it's a Holley?
    • Old Man Mopar
      Old Man Mopar Righteous Dude
      3,190
      603
      Nov 21, 2009
      NW Ohio
      Local Time:
      4:48 PM
      The Trick Flows are going to be hot but about $2k per pair. For a budget and much better
      than any cast iron heads, I would get the 440 Source aluminum heads for $1k/pr complete.
    • C130 Chief
      C130 Chief Mechanical Genius
      3,069
      228
      Nov 23, 2005
      Boise, ID
      Local Time:
      3:48 PM
      So without knowing more about what you actually have now it's pretty hard to say where the first $3000 should go. Do you expect to be able to drive the car for $3000? You could build a basic 450 horsepower 440 for $3000 with the 906's. But the chassis and rest of the drive train will need close to that before it's safe. What about the transmission? Torque converter? Exhaust system? Rear axle?!?
      The best advice here has already been given, start with a good bottom end and work your way out. The biggest way to waste your money is to try to stretch it too thin or build a mismatched setup around parts you can get cheap or have lying around.
    • dukeboy_318
      dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
      41,007
      17001
      Jan 19, 2007
      1600 Pennsylvania Avenue, Washington, D.C.
      Local Time:
      5:48 PM
      I agree map out exactly what you intend for the car to do....then research some similar builds. Chances are, some has done something close enough and you can learn/apply what successes and failures they may have had
    • 68dodge
      68dodge Well-Known Member
      1,479
      309
      Jan 23, 2008
      Armagh, Pa.
      Local Time:
      5:48 PM
      Go with the Edlebrock RPM upper end kit, RPM, heaads cam, intake and Carb. You can not go wrong with the price
    • dkbug
      dkbug Well-Known Member
      398
      5
      May 11, 2011
      Norman, Oklahoma
      Local Time:
      4:48 PM
      Go big block the said. It will be easy they said. You can do it for under 5k they said.
      THEY LIED
    • dukeboy_318
      41,007
      17001
      Jan 19, 2007
      Local Time:
      5:48 PM
      eh...I've got a little less than 3500 in mine.... it can be done, but i scored some awesome deals on parts, damn near free on some of them.
