440 Lower Radiator Hose
Dartman1969
69 Dart Frankenstein
Castlerock, Washington
Good evening all! Looking for a little assistance. I am putting the finishing touches on my 440 Dart (was a 273). I am looking for a lower radiator hose. Drivers side outlet on the water pump drivers side hook up on the radiator. Any suggestions or part numbers would be great! Thanks!!
Nobody makes the correct factory hose yet, Bill Rolik is working on it, but for now you have to use a corregated hose and cut to fit...
I just looked up radiator hoses for a 71 big block Cuda and both the upper and lower hoses fit pretty good with minimal trimming
It really depends on where the outlet is on the bottom of the radiator. The factory big block A-Bodies have it all the way to the drivers side as it will go, the 340 radiators are a couple inches from the end, but the oil filter makes it tough to get the big block hose to fit...
My lower radiator outlet is all the way to the drivers side.
I am using a aftermarket radiator made to fit a 71 Cuda with stock hose locations on the radiator ( lower outlet is about 1 inch inboard from the lower drivers side corner) and you are right the lower hose is a tight fit but it does fit
Bend it any way you want
Continental 60659, not sure if they are available, I think I have an extra one. PM me if you can't find one.
Rock Auto has the Continental 60659, 17.00. It is the bottom hose for all big blocks from like 1966 to 1972. A, B, and C body.
i went to napa and told them that i waned a lower hose for 69 roadrunner had to trim just a little and affordable to.
According to the Factory parts books.
Lower Rad hose for 383 in an A Body is:
67 - 2863207
68 - 2863207
69 - 2863243
According to RockAuto
GATES 20558
They call out the specific part number for 67-68
If you can't find a hose that fits then make the radiator fit the hose. That is what I did. I used a C body radiator and had a shop move the lower outlet over a few inches so a standard hose would fit perfectly.
