Staffords
I'm trying to ID the oil pan on my 440 to figure out what the capacity is. Engine is in a 68 Barracuda. Obviously a mix of parts, dipstick is questionable. The pan has the relief cutout for the steering center link as seen on the 187 and 699 numbered oil pans, however there is no number stamped into this pan anywhere. Makes me think it's one of these reproduction pans from Mancini:MRE - 6 Quart Oil Pan w/Drain Plug MRE A & B-Body Oil Pan Power Package I measured the sump area to the outside lip of the pan and its just about 5.5" deep.... can anyone confirm this is a 7qt (6qt+1qt for filter) capacity pan? Any other details/dimensions on the pan that I can look for that might help identify it? Thank you!
