440 Piston Question
Big Block A body Tech
  1. siuauto
    siuauto Well-Known Member
    335
    46
    Jan 9, 2008
    Joliet Illinois
    Local Time:
    7:06 PM
    Hey everyone, I am building a 440 and I have a set of SRP forged pistons on a set of 6 pack rods. I also have a set of Eagle H beam rods. I would like to put the SRP pistons on the H beam rods but my machinist is hesitate about pressing the pistons off in fear of cracking them. Has any one else heard this or experienced this? Thanks in advance.
  2. Lelo Dart
    Lelo Dart * FABO Gold Member
    1,473
    432
    Oct 10, 2012
    Knob Noster MO.
    Local Time:
    7:06 PM
    Oh yeah very likely. They usually break while getting pressed off. I asked about the old pistons a couple off times and was told they are junk after being removed from the rod. 6 pack rods should be strong enough for most applications. IMO
  3. brian6pac
    brian6pac Well-Known Member
    4,789
    3240
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    8:06 PM
    There is a special tool to hold the rod when pressing, If your shop doesn't have one move on.
    • Agree Agree x 1
    • Plymouth 65
      Plymouth 65 Floorable Deplorable
      1,159
      1086
      Jun 27, 2016
      Mich
      Local Time:
      8:06 PM
      Those 6 pack rods are very heavy, the h beams would be a better option. 65'
      • Agree Agree x 3
      • moparstud440
        moparstud440 Well-Known Member
        289
        95
        Aug 13, 2005
        Keymar, MD
        Local Time:
        7:06 PM
        I went thru something very similar about 15 years ago. Put together a motor used stock rods and Speed Pro pistons. Ending up having an issue with the cam and tore motor apart and bought a set of Scat rods since I had a little extra money. Machine shop ended up breaking 2 of the 8 pistons when removing them. So after buying 2 replacements I got the engine back together. Being cheap and on a budget at the time ended up costing me more than if I'd just bought good stuff to begin with. I also think that a machine shop SHOULD be able to do this, but as with anything some shops are better than others.
      • brian6pac
        4,789
        3240
        Nov 15, 2016
        N.E.Ohio
        Local Time:
        8:06 PM
        OTC wrist pin press, the piston never has any pressure put on it.
        • Like Like x 1
        • siuauto
          335
          46
          Jan 9, 2008
          Joliet Illinois
          Local Time:
          7:06 PM
          Thank You!!!
