440 with a stick and bad judgement
Transmission and Drivetrain Tech
  1. mhuppertz
    mhuppertz Well-Known Member
    194
    22
    Dec 25, 2011
    Tijeras, NM
    Local Time:
    1:57 PM
    Anyone have a high torque 440 with a stick and bad judgement and sticky tires out there?
    Trying to make sure a Dana 60 is an absolute must. Had one from the factory in a '68 Hemi Road Runner I owned (and drove irresponsibly) in an earlier life, and it was flawless. My '69 Dart will have less horsepower, but not much less torque than the Hemi did, so it stands to reason. I have broken several 8 3/4" rears in my rambunctious past, even split the axle tube in a '74 'Cuda 360 (another of the head slapper for selling) did that with a nasty 383 I build with solid motor mounts and and a manual shift TF.
    In the intervening 30 years when I got out of street cars for the sake of my marriage and son, managed to break two Dana 70's in my '93 Dodge W250 Cummins until I went Detroit Locker.
    Alright, I guess I answered my own question. Need a deuce and a half Rockwell and a dump truck trans!
    • Like Like x 1
    • abdywgn
      abdywgn dismantler
      1,043
      438
      Jul 30, 2006
      Darien, Illinois
      Local Time:
      2:57 PM
      8-3/4 should be fine in a lite Dart...it'll just be spinning tires. THEN when it breaks, you can get the Dana.
      I beat my fine spline 4-speed,8-3/4 340 Dart and nothing broke. Even side stepping the clutch.
      And when it had slicks on it, it would bog but not spin the tires. In fact, that 8-3/4 went 11 something
      with a nitrous 440.
      • Like Like x 1
      • mhuppertz
        194
        22
        Dec 25, 2011
        Tijeras, NM
        Local Time:
        1:57 PM
        Good to know, the weight does make a difference, weighs 1k less than the Hemi car did.
      • RustyRatRod
        RustyRatRod Weenie idiot loser. FABO Gold Member
        57,965
        28016
        Jun 7, 2010
        Georgia
        Local Time:
        3:57 PM
        I think you are answering your own question here with your "rambunctious past" as you say. Go the Dana and save yourself some heartache.
        • Agree Agree x 3
        • CudaFactHackJob
          CudaFactHackJob FABO Gold Member FABO Gold Member
          851
          291
          Mar 17, 2016
          Hemet, Ca.
          Local Time:
          2:57 PM
          No, no, put a nine in it!
          • Like Like x 2
          • Agree Agree x 1
          • mhuppertz
            194
            22
            Dec 25, 2011
            Tijeras, NM
            Local Time:
            1:57 PM
            Can't do it! A built 9" is about the same as a narrowed D60, and my stubborn Mopar self respect wouldn't allow a Ferd part in there!
            • Agree Agree x 3
            • famous bob
              famous bob mopar misfit FABO Gold Member
              14,921
              5233
              Aug 14, 2011
              okla
              Local Time:
              2:57 PM
              The only reason I would consider a 9" is "if" I wanted to change gearing very often ----------they have reportedly more drag than a dana 60--------???
            • mhuppertz
              194
              22
              Dec 25, 2011
              Tijeras, NM
              Local Time:
              1:57 PM
              Less friction than a Dana 60, but weaker.
              • Disagree Disagree x 1
              • Locomotion
                Locomotion Well-Known Member
                2,828
                366
                May 31, 2004
                Florida
                Local Time:
                3:57 PM
                It's a documented fact that a Ford 9" is less efficient (more friction/drag) than a Dana 60. It's probably the worst of any commonly used performance rear not only because of the ring gear/pinion relationship, but it also uses an extra pinion bearing! But it is weaker unless you start throwing more money into it than a Dana 60.
                • Agree Agree x 1
                • Dartnut
                  Dartnut Don't hate me because i'm beautiful
                  10,438
                  2615
                  Apr 19, 2007
                  Southern Alberta
                  Local Time:
                  1:57 PM
                  Go with the Dana 60, you will never regret it.
                  I had a '69 Super Bee 383 4 speed car that I put a warmed over '71 H.P. 440 in, and within a month, I blew the pinion bearing out of the 489 case 8 3/4'' rear end doing some burn outs.
                  I put in a 354 Dana 60 out of a rolled '68 GTX that my brother sold me, and didn't have a problem with it in the 20 more years that I owned the car.
                  That sold me on the fact that the factory was right in putting them behind all of the 440 and Hemi 4 speed cars.
                  And it looks damn good to boot............
                • mopardude318
                  mopardude318 Well-Known Member
                  9,659
                  807
                  Jan 7, 2005
                  Gilroy, Ca
                  Local Time:
                  12:57 PM
                  Dana in a Dart. Nothin looks more badass. 9B3BA1C6-CBF3-4B49-A2BD-148BEA19A6F5.jpeg
                  • Like Like x 2
                  • Agree Agree x 2
