1. Mopar87
    Mopar87 Well-Known Member
    51
    16
    Jun 26, 2018
    Lewiston,Id
    Local Time:
    7:44 PM
    I want to lift my 74 Plymouth scamp just enough to give it room to run 31" tires.The plan would be to use it to check out some of the hundreds of dirt roads around here, not necessarily go hardcore offroad, but more or less overlanding.The rear would be easy to get enough lift, things are alot more complicated up front with the torsion bars.The front suspension itself would be easy enough to modify or space the K member down to gain the needed clearance.Then the torsion bar crossmember could be cut and rewelded further away from the body.My biggest problem with that is the crossmember would hang down in the center of the car which would be a great place to get hung up on when the going got rough. Then I thought what if I was to put the car on either a 2wd truck frame or a 4wd ifs frame.If I did that I would gain more robust suspension and possibly 4wd,but normally, I HATE when cars are put on other frames because normally they look very bad.Double bumpers, huge gaps between the body and the frame, Bizzare wheel well fitment,etc.I'm wondering if anyone has any pictures of cars on different frames where the owner actually took the time to suck up the frame to the body and made the conversion almost look like it could have came from the factory that way?
  2. Projectile Dart
    Projectile Dart Active Member
    42
    22
    Jun 30, 2017
    Long Beach, CA
    Local Time:
    7:44 PM
    I am just throwing my opinions out here and this may or may not be the best ideas, but I agree that the torsion bar won't do well with any type of "lift" greater than maybe 2-3". Your other options, before dropping another frame on top, would be to look into a gasser style set up? Aka, solid bar and front leafs etc... mopar a body gasser.jpg
    but it can be questionable how well this set up can hold up to the abuse of offroading and overlanding, depending on how hard you drive it (Some older 2wd Jeeps have pretty nice looking front axles in the junkyards and look beefier than this pic and would retain 5x4.5 bolt pattern and front disks depending on the year!). Under the same idea you can find a solid axle with bigger knuckles to do it safer but then you would be carrying that front pumpkin around for no reason as i assume you will be keeping it 2wd.
    Next option would be to look into splicing in the front part of a frame of a later model ram or dakota that has independent suspension (if you are dead set on that) so that you can find a "lift kit" that fits those models. This wont be easy and it wont be cheap though.
    Last option is the ugliest but might work is to jack up the torsion bars as high as they will go, run pizza cutters on wheels that push the tire as far away from the body as possible, then trim the fenders as needed baja style.
    Either way, this is hot rodding, all that matters is that if you really want this done, get it done by any means necessary and post lots of pics so that we can all enjoy your build... Good Luck!
  3. YY1
    YY1 Well-Known Member
    5,478
    1264
    Oct 11, 2011
    FL
    Local Time:
    10:44 PM
    Do you already have sure grip diff?
    I've gone LOTS of places following 4WD vehicles including vast sugar sand orange groves with just wide rear tires, a limited slip rear and some intelligent driving coupled with situational awareness.
    ...but carry a come a long and snap straps just in case.
    • Agree Agree x 2
    • Like Like x 1
    • diymirage
      diymirage HP@idle > hondaHP@redline
      14,571
      6880
      Oct 12, 2012
      michigan
      Local Time:
      10:44 PM
      i would look at a s10 frame or something similar
      easy enough to build tranny and motor mounts
      and i LOVE this idea
      you got money laying around?
      i got an 08 AWD charger as a winter beater
      it would be great to swap an A body onto that
    • Hellrats
      Hellrats Still wrenching after all these years FABO Gold Member
      837
      542
      Jan 24, 2012
      N.E. Ohio
      Local Time:
      10:44 PM
      Just buy a Jeep
      • Like Like x 4
      • coffeedart67
        coffeedart67 Well-Known Member
        1,165
        28
        May 9, 2010
        Southeast South Dakota
        Local Time:
        9:44 PM
        Saw a metric gm (80's Monte Carlo) that was made 4 wheel drive, had a four link type setup on the front, never looked close enough to see how he did the transfer case.
      • Tooljunkie
        Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
        7,836
        6385
        Jul 22, 2017
        Manitoba
        Local Time:
        9:44 PM
        A daunting task. Rear-easy to get height.
        Front,blocks between k-member and body and re-work torsion bar mounts. Will create a snag point but well designed skid pans will help it considerably.
        I used to follow 4wd’s around on some trails,and using momentum to make up for clearance and traction.
        Install a winch....
      • Mopar87
        51
        16
        Jun 26, 2018
        Lewiston,Id
        Local Time:
        7:44 PM
        I was given a chrysler 8.25 with a welded differential and I was gonna use that to replace the 7.25 thats under the car.I'll probally change it to a LSD or a locker eventually but it can work as a place holder for right now.I've taken my hacked up green dodge to some impressive places and it is 2wd with a welded rear diff.It does piss poor in the rocks but for general trail riding its pretty good.Other than the v6 automatic+ 2.93 gears+ 33" tires...
        As far as the gasser or 2wd jeep front axle it would have to be very tall to clear the oil pan.Then there is also the issue that I'm up in northern Idaho,I wasn't even aware Jeep made 2wd vehicles until a couple years ago.I have never even seen a 2wd Jeep up here.However, the front suspension from a 87-90 2wd dakota might be easy enough to swap under.
        As far as buying a Jeep or other dedicated 4wd,For the couple times that 2wd with a good driver wont get me through something a come along or chain hoist will serve me better than 4wd.Like I said,I don't plan on driving this down hardcore offroad trails I just want to explore the many dirt roads around here.I have enough sense to turn back and try something with a more capable vehicle if things start going sideways.
      • Mopar87
        51
        16
        Jun 26, 2018
        Lewiston,Id
        Local Time:
        7:44 PM
        Now that I think about it I do have a 2wd 94 dakota that I am using for parts.I could cut the front suspension off after I load it up on the trailer to get scraped...
      • diymirage
        14,571
        6880
        Oct 12, 2012
        michigan
        Local Time:
        10:44 PM
        A guy in my town plows with something like that
      • Cope
        Cope Fusing with fire
        2,487
        1942
        Oct 20, 2009
        San Jose, Ca.
        Local Time:
        9:44 PM
        There's a 72 Charger by my shop on a K5 frame. It's very well done.
        I'll see if I can find the pic of it.
        Looks like this is the only pic I got of it.
        • Like Like x 1
        • Tooljunkie
          7,836
          6385
          Jul 22, 2017
          Manitoba
          Local Time:
          9:44 PM
          There was a 68 firebird on a blazer chassis i saw in winnipeg in the late 80’s.done well.
        • Mopar87
          51
          16
          Jun 26, 2018
          Lewiston,Id
          Local Time:
          7:44 PM
          Apparently, I have more reasons to see bumblebee.This is one of the decepicons. Travis-Knight-Decepticon-Car-Bumblebee-Movie.jpg
          • Like Like x 1
          • Pascamp
            Pascamp Well-Known Member
            663
            517
            Feb 27, 2016
            PA
            Local Time:
            10:44 PM
            There's one on rt79 (I think) between Whitney Point and Ithica ny. I used to drive passed it on my way to Cornell. Monte SS with a plow parked in front of a trailer with his other treasures. I always assumed it was on a K5 chassis.
          • 75slant6
            75slant6 Well-Known Member
            4,898
            1275
            May 15, 2011
            Russellville, ky
            Local Time:
            9:44 PM
            im Not sure if they put this on a frame or just installed the axles and leafs to the Duster frame rails. That’s how I think I’d do it, subframe connectors and install leaf spring hangers to the front frame rails
          • diymirage
            14,571
            6880
            Oct 12, 2012
            michigan
            Local Time:
            10:44 PM
            • Like Like x 2
            • 75slant6
              4,898
              1275
              May 15, 2011
              Russellville, ky
              Local Time:
              9:44 PM
              If I remember right, that car was for sale for $2500. Had it been about 5 states closer I would’ve done all I could have to buy it.
            • diymirage
              14,571
              6880
              Oct 12, 2012
              michigan
              Local Time:
              10:44 PM
              thats less then i paid for my plow truck...and i would put a plow on it
              actually, thats on my bucket list
              • Like Like x 2
              • 75slant6
                4,898
                1275
                May 15, 2011
                Russellville, ky
                Local Time:
                9:44 PM
                4x4 Duster with a plow would be pretty badass!
              • Cope
                2,487
                1942
                Oct 20, 2009
                San Jose, Ca.
                Local Time:
                9:44 PM
              • Mopar87
                51
                16
                Jun 26, 2018
                Lewiston,Id
                Local Time:
                7:44 PM
                So just from looking under my 94 4wd dakota and my scamp I could convert the scamp by cutting out the front "frame rails" on the scamp and splicing in most of the frame from a 4wd dakota.Essentially using the frame as a subframe connector and replacing the factory frame rails.I haven't actually measured anything to see just how far off my figuring is though. According to an online tire calculator 31" tires might fit with just a 3" lift.I'll have to go out and actually measure stuff to see what would have be done about the transfer case.On the other hand, I'm not even sure if I want to go to through the hassle of converting it to 4wd just to run 31" tires, that and I would have to track down another 4wd dakota- preferably one with a v8 and a manual transmission.I could swap in the 2wd dakota front suspension and then add in subframe connectors and it would more or less be done suspension wise.ARRR!
              • 67autocross
                67autocross A new iron curtain drawn across the 49th parallel
                957
                389
                Jul 23, 2010
                Winnipeg
                Local Time:
                9:44 PM
                Maybe Hemi Denny could do a front lift kit coil over set-up.... Years ago they had A arm lifts for 73-87 C10 Chevy 2wd trucks and they worked really well.
              • RustyRatRod
                RustyRatRod 30 Degrees Outta Whack FABO Gold Member
                48,128
                13568
                Jun 7, 2010
                Georgia
                Local Time:
                10:44 PM
                Screw an S10 frame. Find a clapped out Dakota 4x4 and go with that. At least a small block will still bolt in and it'll be all Mopar.
                • Agree Agree x 1
                • Mopar87
                  51
                  16
                  Jun 26, 2018
                  Lewiston,Id
                  Local Time:
                  7:44 PM
                  The only way I would run a chevy frame would be if someone gave me said frame then did the fab work to make it fit nice for free.So not very likely.However, I do have a 2wd 94 dakota that I am parting out.I could easily cut out its front suspension when I get ready to haul it off to scrap and graft that in place.Then I could weld in subframe connectors.For a fair bit more work I could go with a 4wd dakota frame,4wd would be nice to have, but 90% of the time it would be extra weight. There is also the possibility of me taking it on harder obstacles because I have 4wd...But I also would have to find another 4wd dakota because I really shouldn't cut up my daily driver.
                • 75slant6
                  4,898
                  1275
                  May 15, 2011
                  Russellville, ky
                  Local Time:
                  9:44 PM
                  Why the heck not?? :D
