roadrunnerh Well-Known Member Joined Jul 11, 2011 Messages 3,195 Reaction score 457 Location Pittsburgh, PA Feb 2, 2021 #1 Hello guys, can anyone help me out? I want to use my 5/16 steel fuel line with the AVS 2. Is the actual fitting on my steel line 5/8-20?
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,295 Location Idaho Feb 2, 2021 #2 Google "inverted flare fittings sizes" inverted flare fittings sizes - Google Search https://midlandindustries.com/section_info/BF_inverted.pdf
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,295 Location Idaho Feb 2, 2021 #3 I guess what you are asking is the thread into the carb body, looks like 5/8x20. You need an adapter from there to 5/16 inverted flare? I see one for 3/8, not 5/16 Inverted Flare Fuel Hose Fitting #8090 For Square-Bore And ABF Carburetors Maybe? Rochester Carter 5/8-20 Brass Fuel Inlet Fitting 5/16" Inverted Flare | eBay
roadrunnerh Well-Known Member Joined Jul 11, 2011 Messages 3,195 Reaction score 457 Location Pittsburgh, PA Feb 2, 2021 #4 Yeah, I ended up buying this fitting earlier today. Rochester Carter 5/8-20 Brass Fuel Inlet Fitting 5/16" Inverted Flare | eBay
