edsrt - I too am in the process of installing a 392 cam in a 2012 Ram 5.7. I did not lock the phaser out an installed it straight up nor do I plan on it.
I did a 2012 5.7 6 speed swap in a E body with EFI Source computer with VVT . It ran like a beast, actually reason I have this current engine I am putting in an Demon.
I bought this engine for the heads and was going to go with a 274 cam and possible putting on a Magnuson. Long story short, E body sold and I still had the Ram 5.7 with all the extra parts and a Demon. Also, I had a Mopar Performance PCM kit, but like stated above, only works on 2013 above due to spacing on toner ring, so sold it. Again, with the Demon build I will be going with EFI Source Gold Box with VVT. Worked well on the the E-Body, and an LS Porsche 944 build, tried, proven and easy to tune and self tune.
Additionally, EFI Source can adjust the harness for LS DBC, and they stock the adapter for LS type throttle body. Again, easy and proven.
