Even more so with a big block!I would start by putting in a Dana 60. If you're going to race it with sticky tires there is no point wasting money on a 8-3/4".
Tom
EV2 Hemi OrangeI’m not getting the “What would I do” question very clearly.
From where I sit, is just paint the body color and the primer and start assembling. Once I got to the elephant ears (if your doing those) I’d mock it up and roll on with the project.
On the inside of the wheel wells, (behind the tire area) you could leave the body color or spray on a bed liner to protect and black out the area for more body POP!
Definitely or a 9 1/4 out of a pickup truck. Either or you will need to have it shortened.I would start by putting in a Dana 60. If you're going to race it with sticky tires there is no point wasting money on a 8-3/4".
Tom
?? That's a pretty broad question.Let me know what you would do? I have plans, but I'd like to hear other ideals. The motor is set!!
+1 on all this.I would also install a US Car Tool stiffening kit, all of it and torque boxes front and back.
Probably going to have to install a roll bar or cage when your et crosses that threshold required at the track you race at. All that stuff is going to make your car handle better, be safer and lower your et.
Yes they can make it up...Always wanted to do a big block A body. Have everything for a big motor except rods and pistons. No A body I can afford in sight.
Your request is vague at best. I would say mini tub it and narrow a Dana 60 so you have a chance at getting it to hook. 3.54 gear.
A six pak hood scoop at a minimum. Alternative is neatly cut hood with a tunnel ram. Maybe a nitrous kit for the well-prepared challengers.
Mine will be an automatic and a mild converter. Street cars make it up on the big end.
I'd say the OP already knows .... look at the top of the DS inner fender.Also looks like you've got some frame rot that you need to take care of before you go dropping a big block in there.
Go over the rest of your subframes and crossmembers with a fine tooth comb before you go too much further.
That's what I was referring to when I said "upper fender flanges". Passenger side has it, too- just not as bad.I'd say the OP already knows .... look at the top of the DS inner fender.
You gotta look at photos closely though, that's for sure.
The lower photo is factory drilled holes, but will be taken care of, right side rail is prefect.Also looks like you've got some frame rot that you need to take care of before you go dropping a big block in there.
Like the Dana, have a couple in my other cars, but I think the 8 3/4 will do for this car, if not, we'll put a Dana in it.I would start by putting in a Dana 60. If you're going to race it with sticky tires there is no point wasting money on a 8-3/4".
Tom
