plymouth500
Member
505 big block mopar $4500
4340eagle crank -esp rods with arp 2000 bolts- clevite bearings- arp stud mains-milodon hemi pickup-milodon 7qt pan-diamond dome full floating pistons with .990tooledwrist pins file fit rings cam is by bullet303-308 duration 640 lift with the 1.5 harlin sharp rockers on it comp cams rebuildable solid lifters
906 heads opened by hand at jersey cylinder head with 80 cc combustion chambers-comp cam springs and retainers-stainless 1piece swirl polished valves 2.19 1.81 from indythese heads flow and run great mopar m-1 intake matched to the heads msd pro billet distributer with 8mm wires mopar alluminum water housing with moroso water pump -marc 6 rib serpentine pullies and bracket mopar performance valve covers
this motor has 10 passes and runs perfect it put my 71 scamp 10.95 124 in the 1/4 short shifting at 6100 rpm i would never sell except I've had a bad family crisis and i need money for my babies.PLEASE NO BULLCRAP i cant handle it right now
