[FOR SALE] 505 stroker
68dodge
Armagh, Pa.
Have a 440 stroked to a 505, 625HP, 653 FT. torque, stroker kit is from 440 source, H-beam rods, platinum series pistons, chevy size H series rod bearing. This motor has 12.4 compression, V-series main bearings, 1/4" main girdle setup, Harland Sharp 1.5 roller rockers 1.5, SFI fluid damper, high torque mini starter, SFI approved flax plate, Hughes 4000 stall convertor, Heads are Edelbrock RPM 75cc fully ported with race valve by Hughe engines, Comp cam roller XR292HR-10 .549-.544, Torquer intake, Quickfuel 1050 carb, MSD distributor. NO Headers just motor. Transmission is a 727 built by CRT with a Hughes 4000 stall. Only has 6 runs down the track and 20 street miles. Ran 11.30s.in a 3340# vehicle. Selling because I am moving. Can here run before it is pulled. $12000. In Pa.
