1. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    16,485
    4876
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    4:21 AM
    Has any 1 ever thought of spacing the K member down like the Hemi Darts and Cuda’s. That should give a lot better trans angle. Maybe u wouldn’t have to cut the hoop above the tranny. Just my thoughts. May be a good idea or a not so good of an idea. Or maybe it’s just plain stupid. Kim
  2. abdywgn
    abdywgn dismantler
    1,486
    732
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    4:21 AM
    would you be dropping the transmission crossmember and/or mount also?
  3. oldkimmer
    16,485
    4876
    Nov 11, 2006
    Local Time:
    4:21 AM
    The Hemi cars didn’t. But with the A518 and the A500 the overdrive section is so much bigger that the mount is quite a bit lower. That’s why I asked this question. Kim
  4. abdywgn
    abdywgn dismantler
    1,486
    732
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    4:21 AM
    Is the transmission mount lower on the trans itself? Not trying to be my usual difficult self but it seems if you lowered both and could get away without notching anything, it would be a win-win! But that is just my thought, not actual experience. I'll be quiet now and listen and learn. Thanks for posting this question. Bob
  5. oldkimmer
    16,485
    4876
    Nov 11, 2006
    Local Time:
    4:21 AM
    Bob, yes the mount is lower because the OD unit is that much bigger. The tranny and the mount would be that little bit lower because the upper brace would still be in there. But I don’t know if it would be too low. I’m just thinking out loud. Kim
  6. abdywgn
    abdywgn dismantler
    1,486
    732
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    4:21 AM
    I get it now. IF the whole brace had to be redone with it in the stock mount location, it might look like a 4WD with a transfer case hanging underneath there. I've got an A518 in the back of the garage but no A-bodies to wiggle it into. I'll keep watching and see what the outcome is. IF you had the rear axle under the springs and a straight axle, it would work out fine...it was a gasser style you were building,right?:)
  7. 89on35s
    89on35s Inferno Red Duster FABO Gold Member
    1,745
    1719
    May 11, 2006
    Martensville Sask. Can.
    Local Time:
    3:21 AM
    I think you'd have to lower it a long way because the width limits you as well. These photos show my modified tunnel with the A500 installed. It is shoved over to the drivers side in these photos. You can see how it was widened all the way to the inside bolts.
    Cley
  8. oldkimmer
    16,485
    4876
    Nov 11, 2006
    Local Time:
    4:21 AM
    Cley, how thick is that top brace. I believe the Hemi cars had the K frame lowered 1/2 inch or maybe more so the hood would close. Kim
  9. furyus2
    furyus2 Well-Known Member
    2,169
    669
    Oct 30, 2010
    weeki wachee fl
    Local Time:
    5:21 AM
    :popcorn:
  10. 89on35s
    1,745
    1719
    May 11, 2006
    Local Time:
    3:21 AM
    The top brace isn't more than a half inch I dont think but I still dont think the width of the OD section will fit unless you remove the sides of the brace.
    Cley
  11. Kern Dog
    Kern Dog FABO Gold Member FABO Gold Member
    4,621
    6501
    May 23, 2010
    Granite bay CA
    Local Time:
    2:21 AM
    What concerns me about this idea of using spacers is that the self centering feature of the K member bolts would no longer exist. This means that the K member could be bolted in out of square to the chassis, causing the car to crabwalk or just handle strangely.
  12. oldkimmer
    16,485
    4876
    Nov 11, 2006
    Local Time:
    4:21 AM
    I thought of that too. what did the Hemi darts and cuda’s have? Ofcourse they were made for the quarter mile. Kim
  13. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    19,201
    7092
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    4:21 AM
    If you're thinking about driveline angles, I don't think it will be an issue.... because
    On my 108wb Barracuda, I am hanging a GVod off the long tail extension, and that makes my driveshaft around 3ft long. And my car is lowered an easy 2 to 3 inches. And I have been able to minimize the angle related vibration and oscillation to just barely perceptible. And most of the time, the CenterForce flyweights are covering it anyway, lol.
    Another thing about the dropped K , that I was thinking about is that; as the K goes down, the body goes up... taking the UCA up with it. And when that happens the camber changes, pulling the top of the wheel inwards. And after a re-alignment,that might work fine in a straightline with a frozen shock. But what happens in a bumpy turn; IDK.
    Well I sorta do; have you ever watched the steering of a Mopar as it's leaving the starting line. As the front goes up, it steers one way, and when it crashes down, it steers another. It's all over the place and IDK how the driver keeps it straight, if it bobbles from the line. Now imagine that in a bumpy turn.
    I mean IDK, just asking.
    If you manufacture your own K-spacers, you can put a centering ring on the frame side, and duplicate the centering device on the bolt-head side.
  14. oldkimmer
    16,485
    4876
    Nov 11, 2006
    Local Time:
    4:21 AM
    Maybe someone has duplicated what the factory used. Mr Norm. Hilt a few cars not that long ago as well as other ppl. Kim
  15. BigBlockMopar
    BigBlockMopar BigBlockMember
    1,754
    755
    May 1, 2011
    Netherlands
    Local Time:
    11:21 AM
    I don't think 'creating a whole new set of issues' is worth it to not having to simply clearance the tunnel.
    Besides your car will look like a 4x4 when you're done, handling is down the drain, steering column needs to angled down, and the spindles are getting too short resulting in much more camber-change during suspension movements. You might as well get a pickup in the first place.
  16. MileHighDart
    MileHighDart Well-Known Member
    4,279
    3784
    Jun 3, 2004
    Lyons, CO
    Local Time:
    10:21 AM
    I'd be wondering about torsion bar alignment with the k-frame and lower control arms being moved down.
  17. abdywgn
    abdywgn dismantler
    1,486
    732
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    4:21 AM
    I spoke with Chris at US Car Tool yesterday about the 518 cross member. He stated clearly the sheet metal in the tunnel would not have to be removed with the use of their Crossmember. I asked him if they have additional pictures of the tranny installed or how many total cars their shop has installed this in and he said one. The customer’s Dart was the reason they developed the cross member.
    He then went into more detail stating the following disclaimers
    - all vehicles have variation is the tunnel area
    - hammering on the tunnel may be necessary
    - grinding on the tranny to releave ribs and protrusions to mitigate interferences
    - interferences with the speedometer cable or elections speed sensor will have to be overcome, may require metal work on their bracket depending on the customers parts used to get them to fit
    - drive line angles have to be checked and adjusted due to engine cradle and motor mount variations (differences k member vs aftermarket k member QA1)
    - warned that there will be several trial fitting several attempts to get the tranny to fit.
    - not required but recommended - remove the pinched and spot welded seam above the Bellhousing and motor. They weld the seam 100% solid from the the inside to make the car more ridged and to allow them to remove the seam. At the minimum he recommended bending the seam forward towards the engine bay where the bolts are located to faciataite bolt up.
    The moral of the story. They have installed one on a custom build where they has the car 100% stripped down and sold many that have not been returned. This is not a bolt in and go install. Expect tweaking and problem solving to get the tranny in the car. Think ahead or wait to purchase the components you are going to use for the TV lever, gear selector and speedo cable.
    I’m going to buy one but I’m going into it with my eye wide open.
    found this back from 2012...did not look up the part but there is some information here
  18. abdywgn
    abdywgn dismantler
    1,486
    732
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    4:21 AM
  19. oldkimmer
    16,485
    4876
    Nov 11, 2006
    Local Time:
    4:21 AM
  20. abdywgn
    abdywgn dismantler
    1,486
    732
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    4:21 AM
    are there any upper ball joints that have longer shanks? possibly in the oval track parts? the spacers are not more than 1/2"...
    reading about that trans crossmember, there is no mention of spacing the k-frame. if you were to use the 67-72 K-frame, use a thinner engine insulator. or fabricate one.
  21. oldkimmer
    16,485
    4876
    Nov 11, 2006
    Local Time:
    4:21 AM
    I looked at another duster with the motor out. It has spool mounts and it appears that the saddle could be ground down some so the mount would sit lower into it. Not sure if doing that would cause oil pan issues with the Center link or not. Also the mount that fits into the saddle could be trimmed on the bottom. Kim
  22. abdywgn
    abdywgn dismantler
    1,486
    732
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    4:21 AM
    could "drop" the center link, cut at each side and drop it with rectangular tubing(?), drill holes in sides and put the center link ends in. I can draw it better than I can explain it!
    there is probably a picture somewhere. done maybe for a BBC in a Chevy II?
  23. ChrisRom
    ChrisRom Active Member
    34
    8
    Mar 25, 2018
    Columbia, TN
    Local Time:
    4:21 AM
    I did a 727 to a518 swap in a E-body (73 challenger). There is a lot more room there than in A-body. There is a nice write up on the web about this(727 to A518 swap – a novice guide). It may be useful for small details after you do the installation - controls, piping etc.
    One idea is maybe looking at a A500 unit instead of A518. It is smaller, based on 904, lower first gear. Have one in my 91 D150 and its a good running transmission.
    Also make sure you get the hydraulic version of these units, not the electronically/computer controlled later units. The electrical connector has to be with 2 or 3 pins, no more.
    I am happy with the A518 and 340 in my challenger. Nice hwy cruiser.
    • Thanks! Thanks! x 1
    • oldkimmer
      16,485
      4876
      Nov 11, 2006
      Local Time:
      4:21 AM
      Paging Princess Valiant. Kim
