[FOR SALE] 576 SMALL BLOCK HEADS
Mopar Mechanical Parts For Sale
Thread Status:
  1. Jeremy
    Jeremy FABO Gold Member FABO Gold Member
    116
    145
    Mar 22, 2010
    Santa Fe
    Local Time:
    10:00 PM
    Contact Seller
    4772576 HEADS built from new castings built by Mopar Performance to replace the 308 head. Never came on a car. Built for Performance, Racing valve job, bronze guides 1.88 Manley Pro flow valves, milled to stock cc's, 10 degree keepers and retainers and NASCAR valve springs.
    Never driven on the street and were on my Duster when it set the NHRA National Record and won class at Indy. I used these heads from 2003 thru 2005. Stored ever since. 20190210_205102.jpg 20190210_205432_001.jpg 20190210_205339.jpg
    $750.00 plus shipping.
    • Like Like x 4
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      3,112
      2109
      Jun 1, 2016
      breakwater
      Local Time:
      8:00 PM
      What all has been done to them?
      If ported, do you have the numbers?
    • Jeremy
      116
      145
      Mar 22, 2010
      Santa Fe
      Local Time:
      10:00 PM
      There was many hours of work done to these heads to obtain there petformance.
    • Jonnylightening
      Jonnylightening Well-Known Member
      222
      28
      Mar 4, 2012
      Pennsylvania
      Local Time:
      10:00 PM
      What the CCs of the Chambers?
    • Jadaharabi
      Jadaharabi FABO Gold Member FABO Gold Member
      4,631
      4198
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      10:00 PM
      Being "Stocker" heads they would not be "ground on" the way most ported heads are.
      Maybe they were later tho.
    • Jeremy
      116
      145
      Mar 22, 2010
      Santa Fe
      Local Time:
      10:00 PM
      The stock cc,s are 64.7 they were milled to be close to this with a little more for them to safely legal. About a little over 65.
    • Jeremy
      116
      145
      Mar 22, 2010
      Santa Fe
      Local Time:
      10:00 PM
      They still look stock.
      • Like Like x 2
      • Jadaharabi
        4,631
        4198
        Jan 8, 2016
        Peoria, Illinois
        Local Time:
        10:00 PM
        Can these heads be used on both the 340 and 360 low compression Motors for stock?
      • Jeremy
        116
        145
        Mar 22, 2010
        Santa Fe
        Local Time:
        10:00 PM
        Yes, they both use the same head. With the latest rules the intake ports are a little large. They are very fast heads. I used these on 1972 car.
        The 915 heads I have for sale were built for present rules but were not legal on some years for NHRA stock.
        • Like Like x 1
        • Jeremy
          116
          145
          Mar 22, 2010
          Santa Fe
          Local Time:
          10:00 PM
          The 587 heads I have for sale were built for the present rules. And were legal for more years than the 915s.
          • Thanks! Thanks! x 1
          • Jeremy
            116
            145
            Mar 22, 2010
            Santa Fe
            Local Time:
            10:00 PM
            What year do you have? It makes a difference on which ones you can use for stock class.
            If your not running NHRA stock class you can run most any.
          • Jadaharabi
            4,631
            4198
            Jan 8, 2016
            Peoria, Illinois
            Local Time:
            10:00 PM
            73-74 Duster 340-360
          • Jeremy
            116
            145
            Mar 22, 2010
            Santa Fe
            Local Time:
            10:00 PM
            They now measure port volume on teardown. They assigned the wrong port volume to the 587 head. They gave the 587 head the same as most others,but they didn't realize the 587 was produced many years after the others and it was produced as a performance head and was bigger. This made the 587 where it can't be used for stock any more.
            The 915 can't be used after 1972.
            Many use the 587 for 1973 and newer.
            I have 2 sets of completed 587.here and another set at my warehouse near San Antonio. Unfortunately I have one of each set here. I plan to go to San Antonio in the near future. I have many casting o different numbers out there.
            • Like Like x 2
            • Jeremy
              116
              145
              Mar 22, 2010
              Santa Fe
              Local Time:
              10:00 PM
              Sorry the first set I was talking about was the 576. My phone sent the text before I was ready.
            • 70aarcuda
              70aarcuda Master Hoader of SBM FABO Gold Member
              14,149
              2198
              Jan 16, 2005
              las vegas
              Local Time:
              8:00 PM
              NASCAR valve springs....any specs on the valve springs....like seat pressure....installed height...coil bind...
            • Jadaharabi
              4,631
              4198
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              10:00 PM
              Left hand bottom corner of your post is the edit button. hit it and then go up and change whatever you want to change. When you're done hit the save changes.
            • Jeremy
              116
              145
              Mar 22, 2010
              Santa Fe
              Local Time:
              10:00 PM
              Don't remember valve spring specs. Usually set the springs up at 200 seat and 400 open. Sometime a little more or less.
              I run stock lift 462/473 and never come close to coil bind. I built these heads a long time ago. Don't think I ever used the 587 heads but not sure.
              • Like Like x 2
              Thread Status:
